Old 12-18-2017   #11
Young1
Young1's Avatar
Default Re: WANTED: Cam position sensor for LT5
That is great Ccmano. I shall start calling those contacts.
My injectors have been replaced.
What is the deal with the shield? Does the 90,91 shield work with modification? Do I have to locate and purchase the 10199080 shield?
Thanks for the info. I was beginning to lose hope. The Beast shall LIVE!
Old 12-19-2017   #12
Jagdpanzer
Jagdpanzer's Avatar
I may have found a suitable alternative cam sensor.
Anyone know the PN for the Weather Pack connector on the end of the OEM cam sensor pigtail and where to get it?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-19-2017   #13
Young1
Young1's Avatar
Ccmano. All the GM parts outlets do not have the sensor. One is not available anywhere in the 50 states. I am not comfortable dealing with White Racing due to reviews. Jagdpanzer I am willing to cut off the GM connector and splice it on to an alternative sensor. Share your thoughts. Yet desperate in Florida.
Old 12-19-2017   #14
WVZR-1
You shouldn't have to cut anything. I've no problem with the mating connector on the "harness side" I'm just compiling the information for what is on the "pigtail" so it could be fabricated.
It's NOT Weather-Pack - that would be to simple! LOL
Old 12-19-2017   #15
Young1
Young1's Avatar
Let's see what TEAM WAZOO comes up with. How about THE FBI guys? Any ideas?
Old 12-19-2017   #16
WVZR-1
The OP hasn't been back so "Young1" do you have the cam sensor removed and on the bench? I believe I've sorted this.
Phil do you have one on the bench?
OP - how about you?
Old 12-19-2017   #17
Young1
Young1's Avatar
Default Re: WANTED: Cam position sensor and Dual mass flywheel for 1990 ZR1 LT5
I can have it removed and on the bench by the top of the hour. Heading home now.
Steve Young
Second Owner
SOLD
SOLD
Old 12-19-2017   #18
Young1
Young1's Avatar
WVZR-1 sensor is on the bench. It is original part 10096172. What next? I shall PM you my phone number.
Steve Young
Second Owner
SOLD
SOLD
Old 12-19-2017   #19
WVZR-1
I used the email you have in the "contact info" and told you what I'd like to have from you. If your contact info is correct you should have my email.
Old 12-19-2017   #20
WVZR-1
Phil has sent me all of the information I need and I'm very sure my information is correct. I'm going to compile everything and forward it to Phil for confirmation.
Young1 - All's well - if you send me snapshots that's fine - if not I believe I'm OK without.
