Old 02-01-2018   #26
Theg
Default Re: 92 LT5 ecu ignition program and control
If there’s knock, then the ECM will retard timing depending on the amount of retard defined in the calibration. Given that the ECM is calculating pulse width to control injectors, doubtful u can use the OEM ECU. A Holley Pro-Jection system may be a viable alternative.
Just a bit confused now . Im unsure if you mean I cant use the stock ecu to run just timing and ignition control when Ive no sensors for fueling returning signals to the ecm .
Basic question is if I removed all injector wiring and map sensors ,TPS, 02 sensors, coolant temp etc etc but left ignition sensors like crank sensor and knock sensor would the ecm still carry out the ignition function when over the 400rpm ?
Theg is offline   Reply With Quote
