Old 04-03-2018   #1
Default "Larsen" (CREE) LED headlights in stock
For those interested in the "Larsen" type LED headlights, Amazon has them back in stock for $120 ea + shipping.
These are projector type, have a super sharp cut-off line, and work extremely well plug n play*.
*You will need to ground the fog light relay, OR use a load resistor (also plug and play) for the fog lights to work, due to the high LED impedance.
File Type: jpeg 0002390_larsen-lights-tuffplus-led-headlight-5-x-7-model-a0102-hi-lo.jpeg (209.8 KB, 35 views)
Old 04-03-2018   #2
Default Re: "Larsen" (CREE) LED headlights in stock
The Genssi/Larsen w/ LED fogs
Old 04-03-2018   #3
Flyman 27
Flyman 27's Avatar
Looks great!
[SIGPIC][/SIGPIC]
Cams by Pete
Old 04-03-2018   #4
They are great. Very happy with them
Old 04-03-2018   #5
The Gennessi/Larsen w/ LED fogs
The LED fogs look good.
Old 04-04-2018   #6
Yes. Easy to install (on a 90).
The TURN signal (amber) lights in the photo are incandescent b/c even with a LED type flasher (turn signal) issues erupted soon as the headlights were turned on. A 6-Ω load resistor(s) installed across the the bulb (reestablishing a ground), and all is well now with an LED (1157 bulb LED equiv) installed. (Will cover in detail in the June HOTB, along with a wrap-up including late mo Zs.)
Old 04-04-2018   #7
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
The TURN signal (amber) lights in the photo are incandescent b/c even with a LED type flasher (turn signal) issues erupted soon as the headlights were turned on. A load resistor(s) installed across the the bulb (reestablishing a ground), and all is well now with an LED (1157 bulb LED equiv) installed. (Will cover in detail in the June HOTB, along with a wrap-up including late mo Zs.)
Paul,
Thanks!
I shall bookmark this!
I have avoided putting these in for some customers due to the reasons you have shown a workaround for, so Thanks!!!
Marty
Old 04-04-2018   #8
cruban
Do you have a link to the lights, the best price I can find on amazon is about $150
cruban is offline   Reply With Quote
Old 04-05-2018   #9
The lights go under several different brand names, apparently. But, here is a link I found.
https://www.amazon.com/XtremeVision-...ct_top?ie=UTF8
NOTE: There were only 15 remaining in stock at the time of this post...
Old 04-05-2018   #10
G8nightman
G8nightman's Avatar
They are great I can see at night after getting the LED lights
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
