Old 04-23-2018   #21
B17 Crew
Default Re: Opinions on this ‘91 please.
Originally Posted by WARP TEN View Post
I would strongly suggest that you get your car up to Marc Haibeck rather than use a local dealer. Or at least give him a call about your symptoms. I was just at Marc's shop for our monthly lunch and he had a car in that had a noise similar to the one you have described that had been diagnosed as rod knock by his local Chevrolet dealer. The dealer then proceeded to rebuild the engine (expensive) and it still didn't run. Well it ran barely like on seven cylinders and still made the noise. As was noted above, injectors are often a culprits on these old cars, and sure enough it turns out whom ever had been working on the car had replaced injectors one at a time, with Marc finding three different brands on the car. Also one was completely dead. They were due to start it up after I left so I don't know the outcome, but I can assure you that Marc and Bob will get it running perfectly (and hopefully they won't have to rebuild the rebuild.) You are really not that far away from Marc's shop in Addison IL--probably five hours-- and having him go through a ZR-1 recently purchased can save untold headaches. It is always worth the money, and it will likely save you a lot of money over time. I did it with my '93 and my '95 and he found lots of little things that I would not have found until it was too late. Saved me lots of hassle and the cars always ran like new. Well, better than new after he did his 510 HP package on the '95.--Bob
That’s a shame the owner has to go through that, I’m sure they work hard for their money and it sounds as if it’s adding up to be quite a bit of out-of-pocket money.
To compare as best I can, I’ve been trying to locate online videos of LT-5 engine starts to see if I can find one with similar start issues I experienced. This search has helped me in that I found several vids that seem to be good examples of how the LT-5 should sound at start-up. Here is another ‘91 that starts perfectly, this is a considerably smoother start that what I experienced:
Link to vids:
Engine start at 2:39.
https://www.youtube.com/watch?v=xwr1dPx1u4c
Engine start at 1:22.
https://www.youtube.com/watch?v=pJus4_8aNxc
Once I find the right car, I will send it to Haibeck to have it gone through to address any issues. And the 510 package!... that must be one heck of a nice ZR-1! Thank you for your input.
B17Crew
B17 Crew is offline   Reply With Quote
Old 04-24-2018   #22
rush91
Link to vids:
B17Crew
That 1st car is the one I bought lol!! And yes, it starts smooth. But over time I do notice chain rattle on start up....it's just a LT5 thing. I have notice after an oil change ( I use Amsoil 10w-40 ) that the rattle smooths itself out. I hope you find the Z your looking for, these cars are a special piece of history
Sent from my XT1585 using Tapatalk
Old 04-24-2018   #23
B17 Crew
It’s small world, what a great looking Z you have! I especially like the color, I currently have a Polo Green/Light Beige LT-4. The start I experienced with the ‘91 was accompanied by significant vibration and a bumping sound. I have learned it can be injectors, coil packs in need of attention, and that changing over to Amsoil/Bosch filters may quell the symptoms somewhat. This site’s members have provided excellent advice, thank you!
B17Crew
Old 04-25-2018   #24
Leroy1
Check to make sure it has the tire tools are there: jack is in a baggie clamped to the spare tire; wrench is behind the driver's seat and is held down with wing nuts.
There should be a tire storage bag and tie-downs in the bin under the luggage compartment, on the passenger side. Baggie and straps are same color as interior (saddle in your case). They are for storing a rear tire in the luggage compartment because it won't fit in the spare tire tray.
S. Lee Sikes, '91 dark red/saddle
Leroy1 is offline   Reply With Quote
Old 04-25-2018   #25
What exactly is this baggie you describe,my 91 has no baggie for the tire straps.
Old 04-25-2018   #26
TX '90 ZR1
TX '90 ZR1's Avatar
I'm thinking this is the "baggie" he is talking about.
Mine is a '90. It is stored with the spare and jack in the spare carrier on mine. It might be supposed to be in the inside compartment, but mine was with the spare.
Tire bag is in this bag.
Kenny
1990 #442
Old 04-25-2018   #27
Attachment 7333
Attachment 7334
O.K. that makes sence,I started thinking -is this some else I need to look for- and the tire bag does go in the spare tire well.
Old 04-25-2018   #28
lfalzarano
Concur on mine also
Old 04-25-2018   #29
B17 Crew
Thank you, this is great information, I was not aware of the storage bag. In the past I have seen the tie-downs in photos, but never any images of the bag.
B17Crew
p.s. that Dark Red Metallic is a very nice color!
Old 04-25-2018   #30
Vette73
Wow! Thank you, this is a great checklist. The noise upon start up, I don’t know if it was generated by the timing chain or not. I currently do not have enough experience with the LT-5 to know if what I heard was normal or not. My take is the sound and vibration were not normal operating characteristics of the LT-5.
I figured the dealer purchased the car from the original owner somewhere in the 14k range. Thank you for your direction on pricing as well!
B17Crew
B-17 crew, there is a member on this forum, had a red 91 Z modified for sale a while back...Look him up, his name is Randy Ransome I believe.....545 HP,polished engine, a lot of money in mods......I think he wanted 25K minimum..Car looked like it was worth every penny..I think he's close to you ...
