Old 06-09-2018   #1
bongo577
Default emergency brake Stuck on my 91
How to get emergency brake unstuck......any tips/tricks?
Thank You,
bongo577 is offline   Reply With Quote
Old 06-09-2018   #2
32valvesftw
Default Re: emergency brake Stuck on my 91
I am guessing here but if the handle is working you may be able to remove each back wheel and see if it can be released there, check the cable routing and make sure not in a bind somewhere. If its the handle that won't operate I don't know what to say except try spraying some type of silicone lube or WD-40 in between the button and the handle.
Old 06-09-2018   #3
bongo577
Thanks for your reply.....Handle is not engaged...pulls up super easy
Old 06-09-2018   #4
When the emergency brake is set, it latches at the tightest handle set point. After the e-brake is set, the handle will pull up "super easy" to the set point.
Depress the release button on top of the handle & at the same time, pull the handle back further than the initial set point to release the e-brake internal latch while keeping the release button depressed. Once released, you will feel tension on the handle as you return it to the forward position.
Old 06-09-2018   #5
efnfast
Like Jerry said. After the brake is set, the handle pushes back down for storage. So to release, super easy until you get to the set point, then pull up, push button, let down.
Sometimes mine won't release all the way and I have to pull back up a little farther, then let it release fast.
Old 06-09-2018   #6
Your first C4?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-09-2018   #7
efnfast
Originally Posted by We Gone View Post
Your first C4? =D>
Took me a bit to figure out how it worked, no pickin' on the guy.
Old 06-09-2018   #8
bongo577
Yep She's my first C4....thanks for the help fellas
Old 06-09-2018   #9
Not picking on him just a question and a congrats.
Couple of links for the OP
https://www.corvetteactioncenter.com...991/index.html
http://www.zr1netregistry.com/Information/TechNet/[AllArticles].aspx
Steve
1990 Red/Red #1473
Old 06-09-2018   #10
32valvesftw
I did the same thing when I got mine, had to call Mike the guy I bought it from, DUH!
