Old 09-27-2018   #11
G8nightman
G8nightman's Avatar
Default Re: Hesitation than cleared itself
Might be a bad O2 but that will throw a code check engine light come on at all?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 09-27-2018   #12
Originally Posted by Vette73 View Post
Well it was cooler today.than Carlisle at least 25 degrees...Great driving weather though..Good air no humidity..
Where is your MAT located?
Old 09-27-2018   #13
Vette73
George....No code ...Had a bad one last year and swapped out..
Old 09-27-2018   #14
George Maz
Fully warmed up, turn on headlamps, come to a stop and wait to see if idle will slow and SES light illuminates. Also can implement additional load of the Air Conditioning running (blower motor max setting 10). If it acts like it wants to stall, you probably have my custom tune installed on your car...lol.
I've become immune to this occasional condition due to being slightly lean at idle...no big deal.
George Maz is offline   Reply With Quote
Old 09-27-2018   #15
George,
His car is a 91 so ur tune wouldn’t work unless someone “translated” it for a 91.
Old 09-27-2018   #16
mike100
I had encountered poor driveability when the weather changed and I was still on winter blend calif gas when we had an 80 degree warm spell in February. Run through a tank before you spend any money
Old 09-28-2018   #17
I agree that fueling may be @ issue. Scanning the ALDL port will give you a pretty good idea how it is running. (O2s don't always throw a code - at least not right away. They can be failing or getting weak long before failing completely to cause a code (I've found).
Besides O2 function, you will be able to get a dynamic evaluation of ALL the sensors: a good place to start!
I don't want to start speculating until we see what the scanner says first. JMO.
Old 09-28-2018   #18
Vette73
Thanks guys....Not too familiar with scanners and such.....Will run this by my guy tommorow or the following week....Will keep everyone posted on the outcome..Which in turn may help fellow members,if such a problem arises with others...
Old 09-28-2018   #19
Was ur MAT sensor relocated?
Old 09-28-2018   #20
George Maz
John, I have Vetronics Tech1A scanner with master cartridge updated...and extra O2 sensors.
Let me know if I can be of assistance to you.
