Old 07-24-2019   #11
Ccmano
Default Re: Switching out Seats
Again... if all you want is standard seats and (like me) you don't care about the lumbar bladder or bolster except to NOT have them cutting off circulation in your legs (I'm 6 foot, 240lbs), you're gonna love the standard 95 seats.
Believe me, remove the seat cushion to access the 4 bolt on the track. Remove them and disconnect the harness, and lift out the sport seat and replace them with the std seats and reinsert the 4 bolts holding the seat frame to the track. Install the bottom cushion to complete the swap and begin enjoying your std seats. (One of the best mods I've done on my 90 and my wife's 91 ZR-1s!
Paul,
How did you wire the seat? The only real problem I see is the control of the seat back angle. On the earlier sport seats it controlled with a switch on the bolster. I’m looking at this mod myself.
H
Old 07-24-2019   #12
EvanZR1
EvanZR1's Avatar
Later seats have a manual adjuster at the front left on the seat base.
Old 07-24-2019   #13
EvanZR1
EvanZR1's Avatar
Here's an Ebay listing that has good pics and is actually a decent deal. Looks like you'd reuse your existing base with these, so you wouldn't even need to rewire the foreward/back wiring harness.
https://www.ebay.com/itm/1984-1993-C...4/193004790143
Old 07-24-2019   #14
vermatrix
its problematic finding the 1994-1996 standard seats as complete units, do you have a link for them? Its easy to find the cusions and or covers, and some of them are pictured as complete seats, but are not. Thanks for your help !!
vermatrix is offline   Reply With Quote
Old 07-25-2019   #15
Paul,
H
I'll look again and let you know for sure, but it is a MANUAL adjustment - a little lever near the corner of the seat, if I recall correctly.
Marc Haibeck commented one time about how comfortable/nice my Z was to drive with those STD seats in it. I'd have to agree! (We put std seats in Ami's Z as well. Love um!)
Old 07-25-2019   #16
I did the swap but did 94 sport seats but used the 94 base seat design. I really like these. I also have a set of 1990 sport seats but they need to be redone.. what I do them I will make them like the 1992.. controls on one side and manual recline by swapping the bases and recline mechanisms
File Type: jpg 14224B3B-EDE7-44F3-9FE6-6425A07EB633.jpg (139.8 KB, 48 views)
File Type: jpg C3D8D806-C2DB-43E2-B990-C902460105C1.jpg (119.6 KB, 34 views)
Old 07-25-2019   #17
BigJohn
BigJohn's Avatar
Are C5 seats to large?
Old 07-26-2019   #18
Your seats take the prize, Jeff!
Old 07-31-2019   #19
Locobob
They'll fit, I've seen it done, but you lose head room.
I've driven a lot of C4's and the base seats from 94-96 are the most comfortable and likely the best option for larger people.
Robert
Old 03-16-2025   #20
ml3126
Question from an older post. I see that the 94-96 seat cushions/ cover have a zipper on the back. Do the seat covers/cushions fit over a 1991 bucket or do you have to use the whole 94-96 seat? Thanks
ml3126 is offline   Reply With Quote
