Old 05-07-2020   #1
BlackSheepz
Default Reverse Light Switch
Hey everybody, I'm getting ready to do an oil change (in the next week or two) on my Z and I remembered my backup lights aren't working. They were working fine until recently and I can't believe that both would go at the same time so I need to check is my Backup switch.
I know that it's high on the drivers side of the transmission but all I'm finding are very old posts where the photos and etc have been removed (thanks Photobucket). This includes the Tech Stickies. (This is both here an on CF)
I also know that the OEM ones aren't available if it is broken. Does anybody have any experience with the aftermarket one? IE THIS ONE from Corvette Central?
Or if it's intact should I just plan to pull the old one and soak the Detent? Will the Transmission lose any oil when I remove the sensor?
Thanks everyone!
--Marc
1990 ZR-1 #2530
Gone but not forgotten:
1988 Z52 4+3
1992 LT1 6 speed
BlackSheepz is offline   Reply With Quote
Old 05-07-2020   #2
Great White
Great White's Avatar
Default Re: Reverse Light Switch
That one from corvette central works well. I tried cleaning my original one but it went back to not working shortly after. To replace it I removed my clutch slave cylinder to gain better access and used a "crows foot" style O2 sensor socket. The oil level is well below the switch so you shouldn't lose any. Just an FYI others above my pay scale have suggested that leaving the car in reverse when parked is what causes these switches to fail prematurely. I personally leave my car in 1st gear when parked to aviod this issue.
Great White is offline   Reply With Quote
Old 05-07-2020   #3
Fully agree! I stopped leaving the car is reverse position. I too installed the switch from Corvette Central with success.
Old 05-07-2020   #4
32valvZ
32valvZ's Avatar
I worked mine with WD-40 and reinstalled it. Been working for about 6 months now. I never park the car in R. Always 1st....
Old 05-08-2020   #5
jw63
jw63's Avatar
Anybody have a recommendation on how to remove the old switch?
Tried tackling this project over winter a few months ago but was unable to get the old sensor out. Purchased an O2 sensor socket to fit over the existing but couldn't get it to move. Perhaps I just need to jack it up higher and get more leverage on it?
Thanks in advance.
'90 #413 Red/Red Sold
'90 #1583 Red/Red
jw63 is offline   Reply With Quote
Old 05-08-2020   #6
32valvZ
32valvZ's Avatar
Thanks in advance.
IIRC, I used an offset box wrench to get mine off. I have mine up on a Kwik Lift, so maybe raising up will help you with leverage.
Old 05-08-2020   #7
Young1
Young1's Avatar
I know I purchased an inexpensive set of offset metric box wrenches at Harbor freight to do it. I think it was 20 or 22 mm.
Steve Young
Second Owner
SOLD
SOLD
Old 05-09-2020   #8
efnfast
I used a 7/8" box wrench and cut it off about 4" long. Worked great.
Old 05-09-2020   #9
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
An O2 sensor socket also works well.
The replacement switches are fine, and should they ever fail are much easier to remove due to their changed / improved design.
Also, these are the first posts that I ever recall suggesting leaving it in reverse may contribute to an early failure of the switch. Makes sense. Love to learn new things! So thanks for mentioning that!!
Marty
Tags
backup lamp switch, backup switch, reverse lights
