Old 10-08-2020   #1
Vette73
Default Headlight door won't close all the way
It won't open all the way and will not close all the way...Headlight works...91....Anyway to close manually ?
Old 10-08-2020   #2
tccrab
tccrab's Avatar
Default Re: Headlight door won't close all the way
The plastic bushings in the actuator mechanism have turned to dust.
Time to remove the headlight unit and replace the bushing.
It's not particularly difficult, but expect to spend a couple of hours.
The bushings are over the counter at your local parts store, cost you a couple of bucks.
Here's a YouTube video on the repair:
https://video.search.yahoo.com/searc...d72587047347b1
If you were local, I'd offer to help for the price of six pack and good company.
'Crabs
Old 10-08-2020   #3
Yes just use the adjustment knob on the side of the headlight housing
Old 10-08-2020   #4
Vette73
Yep yep found the knob ......Thanks for all the replies ....👍
Old 10-08-2020   #5
G8nightman
G8nightman's Avatar
Easy fix took me about an hour to do both sides let me know if you need help John
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 10-12-2020   #6
Vette73
Thanks George...
Old 10-12-2020   #7
Vette73
'Crabs
Hey thank you for the upload...I was 240 miles from my home when one decided to flip up halfway ....
Old 10-14-2020   #8
While we're on the subject, one of the actuator gears in Ami's lights got brittle and some teeth sheered off, causing the motor to free spin. Some say I should have stuck with new nylon gears and bushings, but I opted for the bronze gears and grease.
That car gets fewer than 1000 miles per year, and most of that in daylight. So, I doubt that is a fair comparison. But, just sayin...it is an option to nylon!
Old 08-13-2021   #9
jad1014
Waking this thread up.. Do you put grease where the delrin bushings ride? I see some videos that do and maybe one that doesn?t. I see that you grease the outside of the nylon gear, not sure of the inside of the nylon gear. It?s difficult to press the gear on the shaft without grease inside..
jad1014 is offline   Reply With Quote
Old 08-14-2021   #10
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
no grease.
Marty
DRM500RUBYZR-1 is online now   Reply With Quote
