#11 |
![]() Join Date: Mar 2013
Phil-
I found a thread back in 2017 where you found a sensor that would work for 1990 ZR1s and modified it to fit. Are still making these for people willing to pay? I don't need one at the moment but willing to pay to have one on hand. Currently my 92 is leaking oil and likely needs at least a new seal. I am going to start a new thread for that to see if anyone knows of the correct seal size. But I am afraid of messing with it. Looks a beast to get out even though it is about 12 inches from my hands.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
#12 |
![]() Join Date: Apr 2007
I can make one if you need one.
Stock sensor uses a 21mm OD 17mm ID 2mm width Buna-N O ring seal. Jerry has them: https://www.jerrysgaskets.com/seal-c...r-90-95-7-5c5/ Sent from my iPhone using ZR-1 Net Registry
#13 | |
Now all I need to do is figure out how to get to the darn thing. I think all I need to do is remove the ASR bracket.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 11-07-2020 at 07:46 PM. |
#14 | |
![]() Join Date: Feb 2020
I have exactly the same problems, but my cam sensor is brand new... I've place a new principal ground, engine run perfectly during 3 minutes and after sames problems. i've checked the sensor tension like manual says, look at videos. If you have any informations more or suggest? Fist Test D3 - Ground https://youtu.be/XWhSqp19LXM Second Test A - Ground (2 parts) https://youtu.be/YXQpnXggxUs https://youtu.be/-Uq-8Jdm6GY Here, electric noise and engine problems.. https://youtu.be/PxFXEeReQZE |
#15 |
Phil-
I sent you a PM regarding the sensor but I am not sure it went out. I am interested. Will it be compatible with a 92 and 95?
#16 |
Anyone have a spare camshaft sensor they are willing to part with? I'd like to add one to my spares jic I need one in the future.
PM me if you have one, Thanks Last edited by CamP; 11-12-2020 at 07:52 PM. |
#17 | |
Problem solve with new ECM ![]() |
#18 |
![]() Join Date: Jan 2013
Great...just a matter of "process of elimination" huh? With all the new and advanced technology, sensors, relays, and whatever else they can cram into the "works" now, it just takes longer to find that "needle in the haystack". I have a strong hunch my problem lies in the ECM also. Need to do one more test before I make a decision to get the ECM into the ICU!
