#11 |
![]() Join Date: Mar 2013
Yes but..... it?s not like I can just run to NAPA and replace it. It still works. The leak was minor. The oil pan gasket leaks much more. It seems a little super glue in the crack with a skim of high temp silicone would be worth a try. Epoxy may be an overkill and more risky. My guess the sensor itself is bedded in epoxy internally and should be fine even with a crack in the outer shell. The crack is barely visible.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
#12 | |
![]() Join Date: May 2010
I agree with you to attempt a repair. I didn?t see the crack you have, but I repaired the one on my 90 with very minimal JB Weld and it was fine. Sent from my iPhone using ZR-1 Net Registry
#13 |
![]() Join Date: Nov 2007
Just get one from Phil and be done with it... I had mine in a few days and all has been well since.
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
#14 |
Update:
Repaired the crack with JB weld for plastic. Used a Dremel to plow a small groove along the crack to give it more bite and roughed up with 180 sand paper. Use silicone around the o-ring seal as well. Did not install until everything had cured. So far no leak. Need more heat cycles to be sure but why not try.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp Last edited by KJL; 12-01-2020 at 09:55 PM. |
#15 | |
Good job! That sounds like it will work well. Best wishes!! [emoji1303]🤙🏼 Sent from my iPhone using ZR-1 Net Registry
#16 | |
![]() Join Date: Nov 2016
#17 |
![]() Join Date: Dec 2007
#18 |
![]() Join Date: Jan 2013
Who is Phil and how do I get in touch with him? Just replaced my cam sensor but would like a spare.
#19 | |
Phil is Jagdpanzer on here so you can message him. Sent from my iPhone using ZR-1 Net Registry
#20 |
![]() Join Date: Jan 2021
Gentlemen, is THAT the crankshaft sensor?!? It's located right below the left cylinder head (driver side). Mine is leaky but it isn't round. I removed a small metal piece (like a small fender, tray, latch, whatever) that was secured with an 8mm nut.
The Sensor itself seems to be not round, there is no twisting possible. I can wiggle it, but it doesn't come out. What am I doing wrong?
ZR-1 #638/1991 |
