Originally Posted by secondchance
On the oil filter housing facing forward low an hidden - oil temp sensor
On top of oil filter housing - oil pressure sensor
Right side of filter housing facing down - low oil pressure warning sensor
Under and behind low oil pressure sensor - cam chain tensioner port
Above oil pan - crankshaft sensor
Under the crankshaft sensor, on the oil pan - low oil level sensor
Of course, oil pan gasket can be a source of oil leak also.
Oil leak can be any of above or combination of above locations.
You can immediately eliminate all the ones that are easy to get to.
