#1 | |
![]() Join Date: Feb 2021
![]() Join Date: Jan 2004
if someone uses the old mechanic trick to pack the pilot bearing with grease and try and pound it out it will push out a crank oil galley plug
you would notice the loss of oil pressure. Look over the clutch disk and if it's hot and glazed don't use it. I have good pressure plate disk if you need it. I upgraded to a new stage II I'm dying to try out. |
