12-29-2021 | #21 | |
Re: Weird stuttering issue
Good advice. I only use copper plugs, none of those fancy platinum or iridium types which foul out easy if the coating on the tip comes off. Plus copper is a better conductor anyway. Just have to change them out every 10,000 miles on high performance motors. I will definitely do the plugs now. Not sure why I didn't pull them yet and inspect. I guess moving last year and losing my shop has really thrown off my routine! |
12-29-2021 | #22 |
I was looking at adapting an ITB setup by making a custom base and using some ls3 parts adapted to the LT5 The kits are cheap enough, and we can whittle some prototype parts out of german ply, and scan them and print them in hi temp plastic looking at a cross ram style long runner design similar to the old BB chevy stuff
With all the dollars spent at LPE on an old school bi furcation ltt intake or a fancy mono runner. An ITB would allow that big displacement to breath Thanks Pete for continuing to innovate, I think the LT5 will catch fire when the new Z06 is out similar to how the old NSX bumped up when the new hybrid hit the streets at the high price point. Doesn't make our cars perform any better, just makes them even more of a bargain when compared to the c8!! I see out old ZR-1 prices slowly going backup. As for me, I'm more concerned with putting more miles which = the smiles. Bank account numbers have never given me the same thrill as LT5 WOT
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
12-30-2021 | #23 | |
3000rpm w ~ 20% TPS is where ECM goes into PE mode. I had a similar issue a couple of years ago. Crossing into 3000rpm it would seem to breakup a bit then go on. It would act like a miss.
09-15-2022 | #24 |
Update:
Had read a story some months back about early LT5 engine failures and the discovery of a female at the plant who cold started every ZR-1 with her foot on the floor. The article didn't say anything about a cold engine rev limiter but I suspected maybe the ecu had one implemented after engineering witnessed this crazy abuse. I had lunch with the assistant chief engineer for the C8 LT2 engine in April (I grew up with him, friends since 5yo) and neither he or his boss knew for sure about possible 2nd rev limiter back in that era. And of course my car was too warm still after lunch to replicate the cold performance symptoms. Watch this video. At 13:30 he discusses the story I had read about and confirms indeed a second rev limiter was implemented! https://www.youtube.com/watch?v=6Vs2tdR-9C8&t=810s |
09-16-2022 | #25 |
Some believe you will have engine failure if you do not use AMSOIL!
09-18-2022 | #26 |
I don?t think there is any limiter based on coolant C vs rpm in the calibration other than fuel and SA cutoff. May be that?s what he is referring to. I believe there are limiters based on oil temps but that would be for use of secondaries. Need to revisit the calibration Mask IDs to determine for certain.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 09-18-2022 at 11:00 AM. |
