#1 | |
![]() Join Date: Nov 2007
Pete has removed his and likes the results just fine. And, I spoke w/ Marc Haibeck about it and as it happens he has a chip profile to accomodate the modification, and is experimenting with a new table which (to me) appears to actually boost the low-mid torque a smidgen as well as adding about 5 ponies to the top end. So, I wonder if the mod adversely affects emmissions?? If not, then it really seems to be a "no brainer" to pull them and install Marc's chip. P. |
![]() Join Date: Dec 2003
You will need to keep the electric secondary solonoid,vacuum pump and
differantial MAP(under ECM early) (under plenum later). You will need to run from the Differantial MAP to the open port of the solonoid the vacuum pump to the closed port of the solonoid. Make sure you yank everything else shafts included use Dorman freez-plug #555-108 or equal local part store. Make sure you have Full Power ON when you go for a test drive. Enjoy. This is what i can remember off the top of my head,age is catching up to my memory. If you need more info just post. Pete
Or you could reprogram the PROM to avoid all the secondary vacuum checks....
Pete, did you get the other info I sent the other day? Todd |
#4 | |
What Todd said reprograming the chip. Yes,got it Todd thanks. Pete
#5 | |
who can reprogram the prom to do what todd said ?one last question do you have to remove the head to pull the secondary butterflies and shafts out . pete on my cam settings 1141/2 and 1121/2. have a rear end problem on the black car so havent had a chance to dyno. will be a while now with moving in to the new house and shop.
#7 | |
Todd |
#8 | |
Thanks. That helps. So the ECM thinks the Scndys are closed and not expecting any indicator. But if you do the latter, how does it know to use the Open PT VE and SA tables? ![]() |
