#11 |
![]() Join Date: Jul 2020
3 months??
Innovation Performance Technologies in Aberdeen, NC (near Pinehurst) is owned by a friend of mine.. might want to have them do future work. They're not LT5 gurus but anything else C4 is pretty much all the same and they are very competent. Ask for Jon or Crimson and tell them I sent you. |
#12 |
![]() ![]() Join Date: Aug 2005
Keeping it simple (KISS) are they depressing
the clutch pedal all the way to the floor? ![]()
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! |
#13 |
![]() Join Date: Sep 2012
It sounds as though the problem is linked to the Clutch Safety Switch, in particular the Clutch Neutral Start Switch Rod. As it can be difficult to bleed all the air from the clutch hydraulics after replacing both the master and slave cylinders, an over aggressive use of the clutch pedal (repeatedly side slipping it when fully depressed in an attempt to rid the system of air) can sometimes break / disengage the switch rod. This would lead the no start situation described. The part number of the Switch Rod is 14080260.
Richard 1990, numbers 1821 and 2391 1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's 2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch. |
#14 |
![]() Join Date: Jul 2007
Have you tried to unplug the clutch safety switch put a jumper across the terminals and try to start it? Also you can add a relay (in an older post here) that will use all the switches to power the relay then the relay runs from battery directly to the starter.
It is also possible the starter contacts are carbon covered but I think it is the CSS and related circuit
#15 |
![]() Join Date: Feb 2011
Update, the mechanic did test the clutch safety switch Feb 4 and tested OK. He retested it again on the Feb. 21 and had to replace it. It starts fine now!
Thanks for all your suggestions and ideas. The mechanic at Chevy is questionable. When I went to pick it up shifting was laborious and the clutch didn?t engage until an inch from the firewall. (This all started with the clutch hydraulics going out and shattered the clutch, which was the original repair request to the dealer!) Add to that the idle wouldn?t come down below 2000rpm. It was impossible to drive with both conditions. So it remains in the shop. [emoji20] we?re approaching the 4 month anniversary of no ZR-1[emoji35] Sent from my iPhone using ZR-1 Net Registry Last edited by lfalzarano; 03-01-2022 at 12:32 PM. |
#16 |
So, the clutch pedal needs to be depressed to the floor before disengaging. A few suggestions spring to mind.
The most obvious one is whether the clutch hydraulics have been successfully bled to rid all air from the system. Another visual check - both the clutch and brake pedal should be very close to being the same height from the floor when looking into the car. If the clutch pedal is appreciably lower than the brake pedal, the problem could be that the full stroke of the clutch master cylinder is not being obtained. If you find this to be the case, the reason could be a bent clutch pedal bracket or pushrod, or even an incorrect specification master cylinder. Having a new clutch with lots of meat on the centre plate can exaggerate this issue. If the above checks out OK, moving to the clutch slave cylinder, ensure that it is of the correct specification for both bore size and stroke. Sent from my iPad using ZR-1 Net Registry
#17 | |
Thanks for your ideas. I?ve been forwarding your comments to the Chevy service manager. Sent from my iPhone using ZR-1 Net Registry |
#18 |
Another mystery is why an apostrophe being replaced by with a ? mark on this forum?[emoji16]
#19 |
![]() Join Date: Dec 2003
A bent clutch fork can also cause a low pedal disengagement. Bent and broken clutch forks are an infrequent but known occurrence in the ZR-1.
Lets see an apostrophe '', and a Question mark??? Showed up fine from my keyboard
#20 |
![]() Join Date: Aug 2006
Bent clutch fork happened to me about 10 years ago. Apostrophe being replaced with question mark happens when I use iPad for posting.
