Old 07-15-2022   #1
Young1
Young1's Avatar
Default Haibeck chip and power key
As is common on the 1990 model year the power switch is broken and all parts missing.
Does it make a difference if the contacts are open or closed when car is equipped with the Haibeck chip for secondaries to operate?
Do I need to splice the wires together behind the switch or just leave them open as is?
If switch was operational, what positions are open and closed?
Steve Young
Second Owner
SOLD
SOLD
Young1 is online now   Reply With Quote
Old 07-16-2022   #2
CamP
Default Re: Haibeck chip and power key
I think you can bypass the key with the PROM. Maybe Marc will reprogram it for you.
CamP is offline   Reply With Quote
Old 07-16-2022   #3
jw63
jw63's Avatar
I have a Haibeck chip and it completely bypasses the power key. So I wouldn?t think the switch being wired or broken makes a difference
'90 #413 Red/Red Sold
'90 #1583 Red/Red
jw63 is offline   Reply With Quote
Old 07-16-2022   #4
A1990
A1990's Avatar
Do you have a 90? I could be wrong but I think Marc can program key on on 91-95
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 07-16-2022   #5
A1990
A1990's Avatar
My 90 is wired behind the bezel and the key does nothing
Dennis Fierstein
Old 07-17-2022   #6
aafc
aafc's Avatar
On my 1990 the power key is wired permanently closed as i have the
secondaries on all the time.
1990 black/white # 2546
one of a few 4L80E EQ. ZR-1's
Old 07-19-2022   #7
fastpace
The Haibeck chip is not able to program the key on a 1990, only 91-95. I recently installed a Haibeck chip on my 1990 and sometimes the key switch contacts on mine can be a little touchy so it needs a slight bump to put it back into full power.
When wiring a bypass behind the bezel, does that continually light the "Full Power" light on the dash as well?
fastpace is offline   Reply With Quote
Old 07-20-2022   #8
Young1
Young1's Avatar
The car is a 1990 with a 1991 engine with a 1991 Haibeck chip. . No full power light comes on. I think I will twist the wires together and see what happens.
Steve Young
Second Owner
SOLD
SOLD
Old 07-22-2022   #9
Young1
Young1's Avatar
Power switch wires spliced together. Full power light came on. But no full power.
Steve Young
Second Owner
SOLD
SOLD
Old 07-23-2022   #10
If you have a 1991 chip in the computer and the car is a 1990, the key evens shorted won?t work. You need the 1990 chip, power key is different connections between 1990-1991
