10-28-2022 | #1 |
Crankshaft cup plugs
What are your preferred methods for removing the old crank plugs and pressing in new ones? Does anyone have a tool for that?
Todd Sent from my iPhone using ZR-1 Net Registry
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
10-28-2022 | #2 |
Re: Crankshaft cup plugs
That's probably a good question for Graham.
When pulling seals in motorcycle engines, I drill a small hole in them, then screw in a sheet metal or wood screw. Then grab the screw with vice grips and pull it out. That might work with crank plugs. Last edited by CamP; 10-28-2022 at 04:53 PM. |
10-28-2022 | #3 |
Something like this core plug remover.
https://i.stack.imgur.com/97OhC.jpg |
10-28-2022 | #4 |
For removing the plugs use a straight 1/2" rod approximately 20" +_ long with one end rounded off so it makes contact with approximately 10 mm of the cup center. Starting with the rear cup hammer the rod through until all cups are removed.
For installing use LT5 special tools J-37306, J-38837, Loctite 620 and follow FSM instructions. Sent from my iPhone using ZR-1 Net Registry
10-28-2022 | #5 |
If you are stroking the motor and you have done crank work I highly recommend welding the non threaded expansion ones. My first 380 dropped a expansion plug mins after the engine was installed using the right Kent Moore tools.
10-29-2022 | #6 | |
The other was a stock crank that threw out one of the npt plugs. That's really odd. The FSM mentions removing the plugs to clean the oil passages in the crank, but doesn't go into much detail at all. Seems like an important step that is usually overlooked. Last edited by CamP; 10-29-2022 at 12:19 AM. |
10-29-2022 | #7 |
Or Marc Haibeck. --Bob
10-29-2022 | #8 |
Marc is wealth of knowledge too.
I think Phil has the answer here. He really helped me out recently with an unobtainable part. Great guy! Last edited by CamP; 10-29-2022 at 01:52 PM. |
10-29-2022 | #9 |
Phil has a correct answer. The only things i would add, when replacing stock plugs the kent moore tool is correct, when fitting aftermarket plugs it may not be depending on plug width. Also stock is 0.866 plug diameter, typical aftermarket cranks are .875 and plug widths differ.
Graham |
10-29-2022 | #10 | |
