04-10-2023 | #41 |
Re: FS Single fuel pump conversion for LT5
I'll take one, what do I need to send you?
Andre' |
04-10-2023 | #42 |
PM sent
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
09-30-2023 | #43 |
I would like one of these, how do we order one?
09-30-2023 | #44 |
PM sent
09-30-2023 | #45 |
thank you, I will be ordering from you
10-19-2023 | #46 |
Hi Dan,
Could you send me a PM on how to order your kit ? Thanks in advance !
1990 Steel Blue #2818 ( stock for now ) |
12-11-2023 | #47 |
Hi Dan how do I order?
12-11-2023 | #48 |
01-18-2024 | #49 |
I installed one of your fuel pump conversions last year which ran well for 6 months or so. I I currently have a fuel pressure issue which kicks me out of full power due to low pressure (code 61, lean). The idle pressure is showing 38 psi, thinking it should be around 47-48. Have you any idea what the problem may be other than a faulty pump?
Andre' |
01-18-2024 | #50 |
1) Using the connector plug under the hood at the harness can you check the amperage being pulled by the pumps? At idle & rpms?
2) Did you change both the relays when you changed the pump? Sometimes they are worn & won't pull full amperage. 3) Idle pressure should be around 43PSI give or take a little. 4) Also, pull the vacuum hose off the fuel pressure regulator & see if you smell gas, if so, your regulator may have failed. Please let me know what you find. Dan
