Old 04-22-2024   #11
scorp508
Default Re: Driveshaft removal for speedo gear swap. C-Beam out or not?
Thanks phrogs, sounds like a good method to try when I dig into it.
scorp508 is online now   Reply With Quote
Old 06-22-2024   #12
scorp508
Thumbs up Re: Driveshaft removal for speedo gear swap. C-Beam out or not?
I finally did this yesterday and phrogs is totally correct. I left the C-beam in and moved it towards the passenger side once unbolted. There was plenty of room to undo the rear strap bolts (I need to get a ratcheting wrench for those, ugh...) and pull the driveshaft with the beam still in the car.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
Tags
4.10, gear, speedo, vss
