Old 07-30-2024   #21
tpepmeie
Default Re: Minimum Air Idle Adjustment
Oh, nvm. I saw in the other post where you had been reading the ccm and ride control modules instead of the ECM codes. I recall the 95 has kind of a hybrid ALDL connector. OBD2 style, but the ECM is obviously OBD1 for the LT5.
Old 07-30-2024   #22
Todd,
94 is when GM went to 16pin ALDL which would be used for OBDII cars. LT5 got it altho still OBD1
Old 07-30-2024   #23
Originally Posted by scorp508 View Post
On a cold start when the desired idle is still 1250 it looks like IAC is at 110.
Once warm and desired idle of 850 the steps are around 30-40.
So looks like u should open TB a bit further which then would require fewer IAC steps for idle.
Again, make sure u re-check TPS v whenever u change TB opening.
Old 07-31-2024   #24
scorp508
That was before getting my adjustment done properly yesterday. Now It's low-mid 20s once warm at a 850 idle, but I'll try to get it a little lower when I have some time. I'm nearly out of thread on the stop screw, so there's not much more to give unless I get a longer screw.
scorp508 is offline   Reply With Quote
