Old 09-25-2024   #5
sevensixers
Default Re: FX3 upgrade from 1990 to 1992
First off, I want to thank you for the help. I obviously underestimated the complexity of FX3 system. I did not check the gear height of the old shocks when I removed them. Unfortunately, I got rid of them so I cannot check the old height measurements. I put the new gears at roughly 5.0mm height from the top of the mounting ring. I will try different heights of the gear and see if that helps. I will also go through the procedures in the FSM. I will keep you all posted on my progress. Thank you all so very much !
sevensixers is offline   Reply With Quote
