![]() Join Date: Mar 2008
I was having problems with my 93 ZR-1 and I pulled the codes and it turns out to be the O2 sensors. What does anyone use for O2 sensors? Thanks.
Roy
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. ![]() 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 |
![]() Join Date: Sep 2008
My preference is the Bosch like the originals. As I have headers I did upgrade to the externally grounded type, one more wire than stock, going to frame.
![]() Join Date: Sep 2016
I installed Bosch 13077 45k mikes ago. Solved all the codes then. 21 dollars each on Amazon.
![]() Join Date: Jul 2007
I am using NGK/NTK 21003 with no issues
Also use the NTK 21003 O2 sensors with good results.
Their pigtails are longer which works better with headers. Sent from my iPhone using ZR-1 Net Registry
I use AC/Delco O2s when I can find them. Haven?t tried Denso and have found that Bosch O2s have a tendency to drop signal intermittently resulting in ECM using Open Loop at times.
Thank you for the responses. I contacted Marc Haibeck and he told me to get Bosch 13077 sensors for my LT5. Just waiting for a time to install then and see how that works. I suspect that these are the original sensors since they have the short pigtails. Thank you.
Roy
#10 |
![]() Join Date: Jul 2017
About to install Denso sensors, we'll see how it goes.
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) ![]() |
