Old 10-19-2015   #1
KPW
KPW's Avatar
Default Speedometer LCD Issue
Hi All,
Anybody have any experience with the speedo LCD going a little wonky?
This happened suddenly.
Some of the LCD elements are faded, and there are some that show up (RANGE when in MPG mode, other digit parts, etc.) when they aren't supposed to. Seems to be fairly random as far as which ones. It has gone back to normal once or twice since it started doing this, but usually goes wonky again a day or two later.
The odometer section is unaffected, so I'm OK on fuel monitoring, and I can pull a fairly reliable speed off of my GPS head unit. Of the issues to have, this isn't so bad...still a bit of a nuisance though
KPW is offline   Reply With Quote
Old 10-19-2015   #2
Default Re: Speedometer LCD Issue
Originally Posted by KPW View Post
Hi All,
I have seen and heard about this issue popping up on the C4 section of the Corvette Forum. Usually the cluster needs to be sent in for a rebuild/repair. Normally the complaint is missing segments and bleeding out of the LCD display. I know of no other method to repair this other than mentioned... The cluster needs to be serviced.
Old 10-19-2015   #3
Well, All you need is to replace the LCD. the cluster itself it probably fine, the LCD tends to be the issue. I had it happen on my 89 with the 91 dash, I ended up swapping the LCD only with no issues..
The challenge is finding one. You can buy a 90-91 6K tach Cluster and swap JUST the LCD and that will work too
Old 10-19-2015   #4
aafc
aafc's Avatar
I came across this web site for restoring the LCD panel.
BATEE.COM
Click on DIY Articles
Under 1990-1996 Repair Click on Restoring the LCD Panel (90-96)
Check out video of this process. DIY kit for $59.95 + 5.95 plus S&H
I may have to do this on my ins panel soon. can't see some of the
information.
1990 white/black #2546
one of a few auto (4l80E ) eq. ZR-1's
Old 2 Weeks Ago   #5
crossfire
crossfire's Avatar
BUMP, Anybody else dealing with the faded Speedo display? It seems it is related to film polarization? I'm curious how widespread this is. Maybe it is as random as our windshield delamination.
1994 LPE 475HP, Torch Red #400
1996 G.S. #45
crossfire is offline   Reply With Quote
Old 2 Weeks Ago   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Batee is THE ANSWER!
They fixed dozens and I mean dozens of them for me at Conte's.
Remove it.
Send it.
They fix and send photos of it's corrected performance.
Pay them.
They return it.
Re- install it.
Good for another 30 years.
Marty
Old 2 Weeks Ago   #7
Batte is my recommendation as well. GC
Old 2 Weeks Ago   #8
Russ Sobczak
I ordered repair kit from Batee, followed their explicit instructions, not terribly difficult and display is like new.
Russ Sobczak is offline   Reply With Quote
