#31 | |
Max, Good catch! ![]() |
#32 |
Well, at least I have figured out that this routine is only present on 4 calibrations, and AYBK is one. That happens to be the cal which MaxLean is using.
These calibrations use a 20-byte BLM table (0-15, 16, 17, 18, 19), whereas all the other LT5 use 16-bytes (0-15). I remembered now that BMCB used 20, but never could determine why. More to follow. |
#33 |
Todd,
So this is limited to 90-91 ZRs? Any idea why they would remove that? |
#34 | |
Todd |
#35 | |
Any speculation on the function? |
#36 |
update -- I've finally had a chance to look at this. Several things going on...
cell 16 is the idle cell, used if tps < 1.8% and rpm < 1800. cell 17-19 are used when the 2ndary fuel injectors are on. The cells are divided by the normal RPM boundaries. I'll post the code, although the formatting is not perfect. So I'll attach a txt file for easier reading. NEW BLM.txt Todd Code:
*##################################################### *# BLOCK LEARN CELL UPDATE ROUTINE *# CELLS 0-15 FOR NORMAL OPERATION *# CELL 16 FOR IDLE CONDITIONS (LOW TPS, LOW RPM) *# CELLS 17-19 USED WHEN PT OPEN TO 2NDARY'S ON *# DELAY IS OVER *##################################################### ****************************************************** * GET BLOCK LEARN MULTIPLIER AND ITS CELL ****************************************************** GETBLM BCLR MWFA;BIT2 BLOCK LEARN ADDRESS CHANGE FLAG = 0 LDAB BLMCELL FETCH CURRENT BL CELL CMPB #15 BLS BLIDLCHK IF BL CELL <= 15, GO CHECK FOR IDLE STATE CMPB #16 BNE BLMPTCHK IF BL CELL > 16, GO CHECK PT STATUS ****************************************************** * TEST FOR CONDITIONS TO REMAIN IN IDLE BLM CELL (16) ****************************************************** LDAA KTPSBLML IF BL CELL = 16, CHECK THRESHOLDS TO REMAIN IN IDLE CELL ADDA KTPSBLHY ADD HYSTERESIS TERM (0.8%) TO MIN TPS FOR CELL 16 (1.2%) BCS LD0CB CMPA NTPSLD BCS GETBLM4A BR IF TPS > LIMIT; THEN NEED TO CHANGE CELL GETBLM1CLDAA KRPMBLML FETCH RPM THRESHOLD (1800) ADDA KBLESHY ADD HYSTERESIS TERM (50 RPM) TO MIN RPM FOR CELL 16 (1800) BCS GETBLM2A CMPA NTRPMX BCS GETBLM4A BR IF RPM > LIMIT; THEN NEED TO CHANGE CELL JMP LD176 IF ALL OK, THEN STAY IN CELL 16 ****************************************************** * TEST FOR CONDITIONS TO REMAIN IN PT OPEN CELLS (17-19) ****************************************************** BLMPTCHKBRCLR MW1;BIT1,GETBLM4AIF CELL > 16 AND PT DELAY OVER, GO TO NORMAL BLM ROUTINE … OTHERWISE IF DELAY NOT OVER ANDB #3 …. RPMINDEX = BITS 0,1 OF BLMCELL SUBB #1 LDX #KBLESB1A BLM CELL RPM BOUNDARY--LOW ABX DETERMINE LOWER RPM BOUNDARY OF CURRENT BLCELL TSTB IF RPMINDEX = 0, THERE IS NO LOWER BOUNDARY TO CHECK BEQ GETBLM11 LDAA 0,X SUBA KBLESHY SUBTRACT HYSTERESIS VALUE TO FORM LOWER RPM LIMIT BCS GETBLM09 CMPA NTRPMX BHI GETBLM4A BR IF RPM < LIMIT; CELL HAS CHANGED GETBLM09CMPB #2 IF RPMINDEX = 2, THERE IS NO UPPER BOUNDARY TO CHECK BEQ GETBLM2A GETBLM11LDAA 1,X ADDA KBLESHY ADD HYSTERESIS VALUE TO FORM UPPER RPM LIMIT BCS LD176 CMPA NTRPMX BCS GETBLM4B BR IF RPM > LIMIT; CELL HAS CHANGED GETBLM2ABRA LD176 GETBLM4AJMP GETBLM4B ****************************************************** * TEST FOR CONDITIONS TO ENTER IDLE CELL (16) ****************************************************** BLIDLCHKLDAA NTPSLD IF CURRENT CELL <= 15, CHECK FOR IDLE STATE CMPA KTPSBLML COMPARE CURRENT TPS WITH THRESHOLD (1.2%) BHI GETBLM2B IF TPS > MIN GO CHECK PT STATUS LDAA NTRPMX CMPA KRPMBLML COMPARE CURRENT RPM WITH THRESHOLD (1800) BHI GETBLM2B IF RPM > MIN GO CHECK PT STATUS LDAB #16 IF TPS AND RPM BELOW LIMIT, USE CELL 16 JMP GETBLM60 GO STORE BLM CELL = 16 ****************************************************** * NORMAL BLM ROUTINE BEGINS HERE ****************************************************** GETBLM2BBRSET MW1;BIT1,GETBLM4BBR IF PORT THROTTLE TO 2NDARY'S ON DELAY OVER LDAB BLMCELL ANDB #3 …. RPMINDEX = BITS 0,1 OF BLMCELL LDX #KBLESB1A-1 BLM CELL RPM BOUNDARY--LOW ABX DETERMINE LOWER RPM BOUNDARY OF CURRENT BLCELL TSTB IF RPMINDEX = 0, THERE IS NO LOWER BOUNDARY TO CHECK BEQ GETBLM15 LDAA 0,X SUBA KBLESHY BLM RPM HYSTERESIS BCS GETBLM10 CMPA NTRPMX BHI GETBLM4B GETBLM10CMPB #3 BEQ GETBLM20 GETBLM15LDAA 1,X ADDA KBLESHY BLM RPM HYSTERESIS BCS GETBLM20 CMPA NTRPMX BCS GETBLM4B GETBLM20LDAB BLMCELL ANDB #12 LSRB LSRB LDX #KBLESB3 BLM CELL RPM BOUNDARY--HIGH ABX TSTB BEQ GETBLM35 LDAA 0,X SUBA KBLPMHYA BLM MAP HYSTERESIS BCS GETBLM30 CMPA MAPSD BHI GETBLM4B GETBLM30CMPB #3 BEQ GETBLM36 GETBLM35LDAA 1,X ADDA KBLPMHYA BLM MAP HYSTERESIS BCS GETBLM36 CMPA MAPSD BCS GETBLM4B GETBLM36LDAB BLMCELL MAPINDEX = BITS 2,3 OF BLMCELL BRA GETBLM60 ****************************************************** * PT OPEN CELLS, ADJUST BASED ON RPM ****************************************************** GETBLM4BBSET MWFA;BIT2+BIT3 SET BLOCK LEARN UPDATE AND CELL CHANGE LDAB #16 LDAA NTPSLD CMPA KTPSBLML COMPARE TPS TO THRESHOLD (1.8%) BHI GETBLM4C LDAA NTRPMX CMPA KRPMBLML COMPARE RPM TO THRESHOLD (1800) BLS GETBLM60 GETBLM4CINCB IF TPS AND RPM ARE ABOVE IDLE LIMIT, INCR BLM TO NEXT CELL BRCLR MW1;BIT1,GETBLM40IF PT DELAY IS NOT OVER, THEN GOTO NORMAL BL ROUTINE LDAA NTRPMX CMPA KBLESB2 BLM CELL RPM BOUNDARY--MID BLS GETBLM60 INCB INCREMENT BL CELL IF RPM HIGHER THAN BOUNDARY CMPA KBLESB3 BLM CELL RPM BOUNDARY--HIGH BLS GETBLM60 INCB INCREMENT BL CELL IF RPM HIGHER THAN BOUNDARY BRA GETBLM60 GETBLM40CLRB BLMCELL = 0 LDAA NTRPMX MODIFY BLM CELL LOCATION BASED ON RPM CMPA KBLESB1A BLM CELL RPM BOUNDARY--LOW BCS GETBLM50 INCB BLMCELL = BLMCELL + 1.0 (IN COLUMN 1) CMPA KBLESB2 BLM CELL RPM BOUNDARY--MID BCS GETBLM50 INCB CMPA KBLESB3 BLM CELL RPM BOUNDARY--HIGH BCS GETBLM50 INCB GETBLM50LDAA MAPSD MODIFY BLM CELL LOCATION BASED ON MAP CMPA KBLPMB1A BLM CELL MAP BOUNDARY--LOW BCS GETBLM60 ADDB #4 BLMCELL = BLMCELL + 2.0 CMPA KBLPMB2A BLM CELL MAP BOUNDARY--MID BCS GETBLM60 ADDB #4 BLMCELL = BLMCELL + 2.0 CMPA KBLPMB3A BLM CELL MAP BOUNDARY--HIGH BCS GETBLM60 ADDB #4 BLMCELL = BLMCELL + 2.0 GETBLM60STAB BLMCELL STORE BLM CELL LDX #LBLMM POINT TO LEFT BANK BLM CELLS ABX BLMADD = BLMM + BLMCELL LDAA 0,X CMPA KBLMMAX IF BLM VALUE IS OUT OF RANGE, INDICATE BHI GETBLM65 …NVRAM FAILURE AND INITIALIZE B/L TABLE CMPA KBLMMIN BCS GETBLM65 TSTA TEST LEFT BLM BMI GETBLM85 LIMIT LEFT PE BLM TO 128 - BR IF ALREADY >= 128 BRCLR MWFA;BIT5,GETBLM85BR IF NOT IN PE LDAA #128 IF IN PE USE LEFT BLM VALUE >= 128 GETBLM85STAA LBLM SAVE FINAL LEFT BLM LDX #RBLMM POINT TO RIGHT BANK BLM CELLS ABX BLMADD = BLMM + BLMCELL LDAA 0,X CMPA KBLMMAX IF BLM VALUE IS OUT OF RANGE, INDICATE BHI GETBLM65 …NVRAM FAILURE AND INITIALIZE B/L TABLE CMPA KBLMMIN BCS GETBLM65 TSTA TEST RIGHT BLM BMI GETBLM84 LIMIT RIGHT PE BLM TO 128 - BR IF ALREADY >= 128 BRCLR MWFA;BIT5,GETBLM84BR IF NOT IN PE LDAA #128 IF IN PE USE RIGHT BLM VALUE >= 128 GETBLM84STAA RBLM SAVE FINAL RIGHT BLM BRA GETBLMEX GETBLM65BSET CLCCMW;BIT6 NV RAM FAILED FLAG = 1 LDAA #128 CLRB LDX #32 BLMINITCSTAA LBLMM-1,X DEX BNE BLMINITC STAA LBLM STAA RBLM GETBLMEXEQU * |
#37 | |
![]() Scott |
#38 | |
#39 | |
Scott |
#40 | |
it makes good sense, actually. The fuel tables are different for PT open v. PT closed, so therefore it is logical that you would want the ability to apply a different long-term correction value to each case. One might say that would not be needed, since you'd likely be in Power enrichment under PT open conditions anyway. Not necessarily. Imagine the situation where you make a quick passing maneuver on the freeway, then quickly back off but not less than 4.7% TPS. The PTs would remain open until the TPS lower threshold is met, yet you'd easily be out of Power enrichment. What I just can't grasp is why the seemingly random application of this enhanced BLM code. Why is it not, for example, in BFXB (one of the last service calibrations released)? For the most part, the later released cals are very similar in all other regards. For me, I generally ran my 91 350/500hp in Open Loop. As long as you get the fuel tables very close to ideal, and run with consistent gas and ambient conditions, its not a problem. Its all a matter of preference, really. However, I did have it going on full-time closed loop dual Wideband O2 control for awhile, just to see if I could do it. ![]() Todd |
