Old 10-04-2005   #1
ZR1 MK
Default photo and dimension of damper
I need a front, side and rear photo of the LT5 torsional damper.
I also need the inside diameter of the shaft area or outside diameter of the crankshaft where they mount together.
ZR1 MK is offline   Reply With Quote
Old 10-31-2005   #2
ZR1 MK
Default Re: photo and dimension of damper
I received the pictures I was looking for. Next question.
Did the World Challenge ZR1s use the stock engine torsional damper or an aftermarket unit?
Old 10-31-2005   #3
Jeffvette
Didn't think there were any WC ZR-1's. Just L98 cars.
Old 11-01-2005   #4
ZR1 MK
http://www.speedvisionwc.com/2001/rat/gt-qual2.html
http://zr1netregistry.com/ZR1_racingpictures.htm
Old 11-01-2005   #5
Patton
Patton's Avatar
What the junk,... I posted in this thread earlier... where'd it go?
E-gnomes.
Patton is offline   Reply With Quote
Old 11-01-2005   #6
ZR1 MK
I know you did too because I read you message.
So whats going on?
Old 11-01-2005   #7
Patton
Patton's Avatar
E-gnomes I tells ya. Little short fat buggers with peculiar hats that run around at night screwin shyt up all over the internet. I think Wadsworth is their leader.
