Old 08-25-2008   #21
DScott600
DScott600's Avatar
Default Re: new ZR1 owner with a few questions.
Great write up from the Corvette action center. I have been looking that over good for a few days now. Ricers make me laugh, 1.5 to 2" exhaust with a 15" tip. all hail the mighty civic. haha
DScott600 is offline   Reply With Quote
Old 08-25-2008   #22
rhipsher
rhipsher's Avatar
Originally Posted by flyin ryan
check the duct while running the car, before it all comes apart, until you get too carried away. when it's warm/hot is it soft or firm, sounds dirty , i personally believe the duct collapsing is a little bit of an urban myth thing. i mean ya sure it's possible if the engine temp. gets way up there, 250° F or so & the paper air cleaner is plugged. with a clean/semi-clean K&N well...
It is an urban myth unless you live in palm springs or death valley. Mine stays stiff all the time no viagra needed.
Old 08-25-2008   #23
the duct collapsing is not an urban myth. I'll testify to that as can Keith. pop the hood on your car in the sun, let it sit for an hour then come back and squeeze it. I'd be willing to bet that you will be able to almost collapse it. I can remember watching the duct get sucked closed on keith's car on the dyno in BG several years ago. The stock duct sucks. I went though 4 before I got smart and bought the coplin duct.
Old 08-25-2008   #24
actually it's not
Old 08-25-2008   #25
flyin ryan
flyin ryan's Avatar
i can squeeze the stock duct cold if i want, not a big deal, i'm not saying they are all perfect but i don't believe they are ALL junk either. i'm not one to wave the General's banner, believe me. depends. it's all about draw. where's it drawing from (air cleaner inlet) & how much is the draw (stock LT-5 or modified) . a person can put their hand over the end of a vacuum cleaner & watch the hose snake up on the floor. i'm trying to help DScott600 by keeping his eyes open before he goes & spends his money with both fist's. check it out first, doesn't cost anything . how many cars did we chassis dyno at the PNW gathering a few weeks ago, eleven i believe. inside a building (warm) i didn't see any duct's get yanked off because of the infamous collapsing. again, not saying it's never happened. i see guys overbuild stuff that just doesn't matter all the time. i try to focus my attention (time,effort,money,etc.) on things i KNOW help.
Old 08-25-2008   #26
I don't think that all of them are junk, but time + heat = junk. you can see the duct sucking down under load, but since it's kinda hard to drive with the hood up or off, it's nearly impossible to see. Keith's car is a low mile stocker that had a very low base line reading, knowing the car was a low mile 90 we were thinking anything from bad plugs to bad prom to bad injectors. It was mark haibeck who thought to check the duct and sure enough it sucked down like an accordion. If you don't want to believe that the stock duct is not the most high quality piece ever made, so be it. However, since the coplan duct is no longer made (cost all of $25 back when he had them), and the haibeck duct is all of $40 http://www.zr1specialist.com/HAT%20W...ucts/hoops.htm what is the harm in reinforcing it and just making sure? If you drink coffee it is free to reinforce. there are very few parts offered by people like haibeck or coplan for these cars that don't help to improve performance.
Old 08-26-2008   #27
Heres what your looking at.Best thing to do is strip everything from the valley.There is a small drain hole that plugs very easy,it plugs up you get a water cooled starter,not good.[IMG][/IMG][IMG][/IMG]
Old 08-26-2008   #28
cward
cward's Avatar
Great pics for what you see under the plenum. Just my $.02 on the vacuum pump: My Z did not have one and ran pretty good. I was told by someone (Graham B) that the Yanks made them put one on for some edge of the envelope cases. I drove my Z pretty hard both on the street and racing of all different kinds and to my knowledge did not suffer from vacuum loss. However, I know many of the Z owners will say they need the pump. Just saying that mine did not. And that old Z of mine did run pretty good for what it had done to it.
Curtis
cward is offline   Reply With Quote
Old 08-26-2008   #29
Aurora40
Aurora40's Avatar
the the air duct will collapse if you have the stock one, you need to reinforce it somehow. Since it seems the inexpensive ones are no longer made a coffee can cut down the side with the bottom taken out inserted inside the duct will work
FYI, I bought a new duct for maybe $15. Much stiffer than my 18 year old one. I have the Haibeck inserts, but really I think with a new duct, no reinforcement is needed.
Old 08-26-2008   #30
DScott600
DScott600's Avatar
The car does run fine with the pump not working, but it is nice to know it is there and easy to tell if you have a vacuum leak if it doesn't go off or cycles on and off. Since the part is less then 100.00 right now I think I'll go ahead and get it if the one I have can't be fixed.
