Old 10-16-2008   #4
Default Re: WOT Tuning
Paul,
The answer is that neither were pulled immediately after a run and then shutdown. However, as you look at the porcelain, there are 3 regions. Closest to the tip being idle, mid-section indicates cruise, and the bottom is WOT and therefore the need for the plug cut. Ideally, the bottom should have a wispy tan look to it. I may try to borrow my wife's tool for examining childrens ears. That supposed to work too but I had these plugs laying around and thought I'd give it a shot. After the track, I decided to try a plug one step hotter but I still need to pull fuel out of the WOT zone of the VE MAP.
I use an 8x eye loupe, but I'm too cheep to start cutting my platinum plugs, I guess
Anywayz, mebby ya need to have a spare plug or two and shut 'er down at the trap and coast into the turnout area. That way the results won't be compromised.
A quick read some may find interesting:
http://www.dragstuff.com/techarticle...ark-plugs.html
P.
