Old 10-20-2008   #31
Default Re: LT5 Assembly Project
No I was able to loosendthe bolt with a standard socket set and gripping the balancer with one hand. used the screwdrier to lock the crank, came loose fairly easily.
92 ZR1
#234
Old 10-20-2008   #32
Jeffvette
No I was able to loosend the bolt with a standard socket set and gripping the balancer with one hand. used the screwdrier to lock the crank, came loose fairly easily.
92 ZR1
#234
You need to be careful of the reluctor wheel.
Old 10-20-2008   #33
Jeffvette,
Out of the car, what is the best method for the center bolt. Pipe wrench(strap)?
92 ZR1
#234
Old 10-20-2008   #34
Jeffvette
Put two flywheel bolts in and a pipe in between them. When rotated it will lodge itself against the engine stand.
Old 10-20-2008   #35
Removed the water pump, appears to be alittle rust on the back of the impeller, will post pics later. I also made sure to tape down the bolts in order to keep them in order on the water pump.
Removed the timing cover bolts, I assume that the seal needs to be removed prior to pulling the cover off. I will tackle that piece tomorrow.
92 ZR1
#234
Old 10-20-2008   #36
Seal remains in place in the front cover when it's removed. Word of caution, be careful with the large metal "washer" on the crank. The face is a precision lapped flat surface for sealing against the carbon/graphite oil pump seal. If it is dinged or scratched, the oil pump seal will leak.
Old 10-20-2008   #37
Whats the best process for removal, cover seems very tight.
92 ZR1
#234
Old 10-20-2008   #38
flyin ryan
flyin ryan's Avatar
or use a long Grade 8 bolt & let it hit the back-brace of your stand. either way will get it done.
Old 10-20-2008   #39
Thanks Ryan, but looking for timing cover removal.
92 ZR1
#234
Old 10-20-2008   #40
Jeffvette
92 ZR1
#234
You have "all" the bolts removed. And nuts?
