Old 04-16-2009   #1
Default Car back to running like sh!#
Car ran great Sunday, today shudders above 2500.
less than 40 miles on new
pumps
coils-Wells/Autzone
fuel pump
Place your bets.... Car runs at low rpm and idles fine.
LGAFF is online now   Reply With Quote
Old 04-16-2009   #2
Default Re: Car back to running like sh!#
Bad gas? No gas?
shudders how about 2500??
Change plugs and Wires yet?
Maybe loose nut behind wheel?
Old 04-16-2009   #3
jonszr1
jonszr1's Avatar
sorry to hear its being a piece of sh!t. but if i had to bet ,i would say iyou could have a vacume leak in the secondary spyders .ie one of the ball ck valves leaking.or maybe some trash is clogging a injector .hope you find it .
Old 04-16-2009   #4
I changed the fuel filter also......and yes it is on correctly!
Old 04-16-2009   #5
Block the air horn with a flexable folder while running and tell us what happens next Lee.
Old 04-16-2009   #6
Idles too good for a vac leak.
Old 04-16-2009   #7
Injector?
Old 04-16-2009   #8
Checked fuel filter is on correctly.....yes there is gas in the car smartass, fuel pressure jumps to 52lbs when switched on then drops to 43lbs.
I am thinking my new autozone coils might suck.
I am not getting any codes.
Old 04-16-2009   #9
How long does the presure hold after shutting it down?
Old 04-16-2009   #10
steady at 43 for hours
