Old 09-02-2009   #1
ralph92ZR1
ralph92ZR1's Avatar
Default Water Pump Removal
Need some advice. I am removing the water pump to replace the gasket. Have all the bolts loose. To revove the A/C compressor bolt from the pump housing, is it the bolt going down vertical from the left side of the A/C pulley housing as you look at the front to back? Or is it the bolt going in from the water pump housing toward the engine? What is a good way to break the pump loose from the gasket since there is not a good surface of the pump housing to tap with a rubber hammer??
Thanks for the advice !!!
ralph92ZR1 is offline   Reply With Quote
Old 09-03-2009   #2
Default Re: Water Pump Removal
Ralph a slight tapping with a rubber mallet should free it. Just remember to keep track of where all those bolts go as they are all varying sizes and lengths. I cant remember on the bolts but I believe both need to go.
Old 09-03-2009   #3
ralph92ZR1
ralph92ZR1's Avatar
Thanks, will try this weekend
