Old 10-25-2009   #1
soslow
soslow's Avatar
Default What is the best oil for the beast.
I have a 1990 ZR-1 with only 7500 miles. So far I have been using Mobil-1. I read that most oil companies removed the zinc from the oil formulations because it destroys the catalytic converters but zinc was the ingredient that afforded the most protection to the cams. Does anyone have any ideas what the best oil would be for the beast? I heard that Hy-per lube sells a zinc replacement additive, but you need 2 bottles at twenty bucks each for the 12 quart capacity LT-5. I want to use the best oil available, without resorting to expensive additives that may or may not work. Any input from my Beast Brothers?
soslow is offline   Reply With Quote
Old 10-25-2009   #2
Kb7tif
Default Re: What is the best oil for the beast.
Here is a good one, highly recommended by people who know.http://www.amsoil.com/storefront/amo.aspx
Old 10-25-2009   #3
ZR1Vette
ZR1Vette's Avatar
Yep..do a bit of 'search' and your find a load of discussion about lubricants etc. For many (including me) the conclusion is the Amsoil AMO syn 10-40 high zinc is the way to go
Old 10-25-2009   #4
Aurora40
Aurora40's Avatar
I use Redline because it has similar ZDDP levels to the oil the Z was spec'd at. And also I can buy it locally. The idea of having oil delivered just doesn't do it for me.
Old 10-25-2009   #5
Hammer
Hammer's Avatar
Talking Re: What is the best oil for the beast.
Amzoil AMO 10-40 and a Bosch filter for me. I think Redline would be great too, but they want $11 a quart around here for it.
Old 10-26-2009   #6
I'm also using the AMO 10-40 with the added zinc. But, it is at $100+ per oil change on the Z, if I do it myself!
Marc Hiabeck did a nice article in "The Heart of the Beast", back about - wazzit 2 years ago? Might do a search. Very well thought out article, and the ZR-1 is Marc's "rice bowl" (so I pay attention when Marc makes a recommendation...or later wish I had, on occation!!).
P.
Old 10-26-2009   #7
rkreigh
the amsoil is great stuff, and the M1 extended has the higher zinc if you are concerned
the LT5 has pretty light spring pressure and a generous lifter
once broken in, I'm not 100% positive how essential the high zinc is but it certainly seems like it's wise and can't hurt
Old 10-26-2009   #8
jimmac28
jimmac28's Avatar
P.
http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf
I think this is it Paul.
jimmac28 is offline   Reply With Quote
Old 10-26-2009   #9
I'm using Castrol GTX 15W-40 Diesel. Has all the ZDDP necessary based on the discussions in this forum and the list serv. $4/qt.
Old 11-04-2009   #10
93RubyZ
93RubyZ's Avatar
Originally Posted by jimmac28 View Post
Thanks for the link. It looks like Marc also recommends Amsoil 10W-40.
93RubyZ is offline   Reply With Quote
