#3 | |
Some guys drill a larger 3/8 inch hole to the drivers side of that drain hole out toward bell housing. I elected to not drill the second drain hole as I will just blow the original drain clean from the bottom of the drain tube once in a while with compressed air. Use red Loctite 262 on two starter bolts when you reinstall starter and on four coil frame bolts when you reinstall the coils. Last edited by Dynomite; 02-22-2010 at 12:12 PM. |
