Old 05-02-2010   #41
Sgreg
Sgreg's Avatar
Default Re: Camshafts almost done
Originally Posted by tpepmeie View Post
Could you please tell us who your grinder is ????
Sgreg is offline   Reply With Quote
Old 05-02-2010   #42
Tyler Townsley
You probably have your valves by now but was any thought given to using some cut down NASCAR valves. They have gotten pretty slick about valve design and have used items for sale at real reasonable prices. Rob Dewile has put togeather a couple of sb2 motors with used NASCAR stuff and could give recommendations on who has it and how to get it. I think one of the motors he has cost him about 5k-7k using heads that probably cost the NASCAR team 25k plus. Fastlane was at 800-875 hp on the 431 motor not sure on his cam designs.
I lenghtened the prime pulse time on the p-type start cycle and it seems to have solved the start problem.
You coming to the gathering?
Tyler
Old 05-02-2010   #43
tpepmeie
Tyler
Nope. won't make it this year. First time in awhile I won't be there. Glad to hear quennie is getting well.
todd
Old 05-02-2010   #44
tpepmeie
My valves and bronze guides are from SI Valves... 39.5mm OD intakes, 7mm stems, stainless steel.
Springs are now Eibach, for a Porsche application
Retainers are custom Xceldyne, locks are std Xceldyne top locks (Paul, I am aware this is what Corey's done for yours, too. They make good stuff )
Cam followers are INA lightweight hydraulic buckets.
Todd
Old 05-04-2010   #45
Sgreg
Sgreg's Avatar
I just got my pretty Stage One cams back and I ain't telling anyone who my grinder was Na Na Na Na Na Na!!!!!!!!
Old 05-05-2010   #46
Pete
Pete's Avatar
Greg,the issue with telling is there is no loyalty anymore.
What i'm saying is if someone paid for a master grind the company will sell it to whoever.
If someone put out money for the master grind and more money and time for testing is it fair for the guy who put out the money/time.
If the company was smart they would not charge for the master grind this way there name would be posted all over and could've made more money in quantity sales instead they get a master grind charge and that's it.
If somebody cuts me a check for the master grinds i will tell you and then you post the info since you paid for it.
A little story, i know who cuts cams for SGC i decided to call and ask them to cut me a set of exhaust Stage I's he told me i had to call SGC since they paid for the master,i could not believe my ears and what i was hearing i finally found one person that was in business with integrity and loyal to his costumers.
WOW
I wish they were more like him.
I called SGC no reply i guess i will have to pay for master grind for my Stage I's unless somebody sells me there Stage I exhaust cams Greg??
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-05-2010   #47
Sgreg
Sgreg's Avatar
Pete, thanks for the explaination. Didn't mean to be an a-hole about the secrecy surrounding various cam grinds. It is a business. I for one have no interest in doing cam design but I do understand protecting cam designs for different applications. They are at the heart of a good result. As I understand it, almost everyone that does cam design and testing has a cam grinder they trust. I was more interested to know who the pros ( yourself included ) use to grind cams than to know design info. I presume you send your designs out for grinding. I say that because it takes a bunch of machine equipment to be in that business and most tuners I know don't want their money tied up in equipment that would get limited use. Cams and cam design have always been a bit of an enigma wrapped up in a blanket !!!!!! We less gifted techies know when they work and when they don't by the neck snap factor !!
Old 05-05-2010   #48
phrogs
phrogs's Avatar
I can't believe they wouldn't cut you a set I guess they don't like money
WOW
Pete
Old 05-16-2010   #49
tpepmeie
Finally finished. Almost too pretty to run...
Grinding the heads to clear is no fun, though!
Todd
Old 05-17-2010   #50
Pete
Pete's Avatar
Todd
Todd,Damn i totally forgot about that.
I could've told you how to do it without having to clearance/grind the head.
Todd you have some big lobes
Missed you at BG this year.
Missed out on a great party.
It made Rock Stars look like nuns.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
