#9 | |
![]() Join Date: Jun 2010
I have a scanner (3120) but have frankly only used it in static mode. I am not sure if it does real time. I'l go check. Any recommendations on scanners if not. I did not add any techron or other additive. It may be worth a try. I might swap out the O2 sensors just because they are inexpensive and 20 years old. I have spark gap a bit high at 042. I might drop that to stock, but I doubt that matters. In any case, thanks for the input, much appreciated! Mike |
