Old 09-04-2010   #11
phrogs
phrogs's Avatar
Default Re: New member, new car with problems
The seatbelt light and airbag light go and in hand, I personaly haven't been able to get mine to go out, so I unpluged the airbag light.
JOHNNY P
Currently own
Old 09-04-2010   #12
cvette
Originally Posted by GreyZ View Post
I'll swap out the stock PROM that the previous owner supplied and see if anything fixes itself. That's a great idea. I'll read up on here on how to do that swap
Called Napa, they have a oil pressure switch on the shelf. I'll read up on here and see if the # is posted somewhere to compare to Napa #, make sure I use the correct one.
The correct part # for NAPA is MPE OP6677SB.
Charlie
cvette is offline   Reply With Quote
Old 09-04-2010   #13
John Boothby
John Boothby's Avatar
The "InfRest" light is easy fix. Remove both of the front sensors and clean the contact between the sensor and frame. If that does'nt work, then you can diagnose the bad sensor and replace it. Drivers side is pretty easy but the pass side is tough to get to, but doable. Seatbelt light is tied into the senors also, I beleive. There is a thread on this under under "ZR-1 How To's", "Airbags", "SIR Failure"
Old 09-04-2010   #14
Out of town for a week, so will have to wait till I get home to do some more trouble shooting, and check for codes etc. I will wiggle the switch and see what happens.
I did also notice when pull up to stoplight engines idles couple hundred higher than normal for a few seconds then bumps down to normal idle speed. Thank you all for the input and links, it's very encouraging that I may be able to fix these items myself. Thanks
That's the way the DFCO is calibrated. That can be changed in the tune.
Old 09-15-2010   #15
GreyZ
So I got home and did some troubleshooting. Found the power key was not making good contact inside switch. Wiggled it a bit and it started working. Wow what a difference in power. There is still no light indicated full power on the dash but there is a big difference in power now, so it is definately working. Checked my vacuum pump, it comes on and does not cycle so that is good. The oil pressure problem, went to change out oil pressure sensor and realized I didn't have correct tool. Put connector plug back on sensor to go buy the correct tool. And it started working on its own. Must have been a bad connection, have driven it about 1000 miles since and has been working perfect ever since. Will keep the new sensor and tool just in case it's needed later on. Had a fellow ZR-1 enthusiast test drive my car to see if it is working correctly, and check out the noise on deceleration, he is convinced that with the Doug Rippie Chip it is supposed to do what it is doing. He gave me the thumbs up, plus invited me to join his corvette club, so we had the first meeting yesterday. What a great group of folks. Thank you all who have helped me out answering questions, it is very much appreciated. Been thoroughly enjoying my new ride and have put over 1000 miles on it in the last several days...what a pleasure to drive.
GreyZ is offline   Reply With Quote
Old 09-16-2010   #16
Kudos to JRD for being spot on that one!
Old 09-16-2010   #17
jrd1990zr1
jrd1990zr1's Avatar
jrd1990zr1 is DAMAN
In Solutions under the Heading IGNITION http://www.zr1.net/forum/showthread....7024#post87024
Just lucky guess or maybe an unlucky guess. Had the problem on both of my cars.
