Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 10-09-2010   #1
jrd1990zr1
jrd1990zr1's Avatar
Default High level brake light
Just had my 1990 judged.
I got dinged for the lens on the high level brake light.
I have no reason to believe it has been replaced.
Could a few 1990 z owners post up the writing (letters and numbers) from both the left and right side of the red HLBL lense?
I am looking for the raised numbers and letters. Also last 5 numbers of your VIN for bracketing purposes. My vin is 02124
Thanks, John
Old 10-09-2010   #2
Default Re: High level brake light
if it matches the rest of the glass on the car it should be either 88 or 89. I haven't looked at my tail lights in a while and can't remember what it says
Old 10-10-2010   #3
jrd1990zr1
jrd1990zr1's Avatar
Kevin,
On the left (driver's side) of the high level stop light it should say DOT and 2 numbers.
On the right side it should say GUIDE a number and a letter.
Could you look and send me a PM with the information your last digits of your VIN and mileage on your car.
I have 2 z's both have the same lense. I believe there is an error in the new NCRS manual and I am looking to obtain additional information to contact NCRS.
Thanks, John
Old 10-10-2010   #4
Originally Posted by jrd1990zr1 View Post
Kevin,
Thanks, John
i'm not around the car right now but let me see if I can call and get that info for you. the car is #1433, has 61xxx on her and the lens is factory as far as I know
just heard back dot 86 and guide n
Old 10-10-2010   #5
gbrtng
gbrtng's Avatar
My 91 built Nov 90: Lens says "DOT 86" on the left and "GUIDE 1Y" on the right.
My guess is the 86 related to the year the HMCSL was required, and the 1Y is the
die cavity number. How many dies ? Who knows.
Old 10-10-2010   #6
John Boothby
John Boothby's Avatar
My 90 VIN 148 has "DOT 86" and "GUIDE 1Y" for what it is worth.
Old 10-10-2010   #7
95 LT5
95 LT5's Avatar
Hi John,
On my 95, it is also
DOT 86 GUIDE 1Y
'95 ZR-1
RED/GRAY
#261
'95 ZR-1
BLK/BLK
#268
'89 6-Spd
FX-3,Z51
BLK/BLK
95 LT5 is offline   Reply With Quote
Old 10-10-2010   #8
902066
90 ZR1 vin. 2066 11,000 miles.
DOT 86 GUIDE 1Y
902066 is offline   Reply With Quote
Old 10-11-2010   #9
gbrtng
gbrtng's Avatar
Thanks, John
What does the NCRS manual say?
Old 10-11-2010   #10
ZRapid-1
My 1990 ZR-1 has:
Left Side Right Side
DOT 86 GUIDE 1Y
My VIN is a few hundred higher than yours.
ZRapid-1 is offline   Reply With Quote
