Old 05-04-2015   #21
SteveCanyon
Default Re: Full engine Power light
OK, pulled the switch out and fixed it, took about an hour and everything is working now. Now on to the next fix as I am getting a misfire from one of the injectors so will tackle that as soon as I get them in. Also waiting for my OBX cat back and Hailbeck chip to come in, as well as my A-Molds. Money pit already!
SteveCanyon is offline   Reply With Quote
Old 05-04-2015   #22
NVMYRC51
Man I am glad I found this. I just noticed my full power light not being on all the time and I never turn it off. Now I can rebuild it.
Craig,
NVMYRC51 is offline   Reply With Quote
Old 05-04-2015   #23
PhillipsLT5
PhillipsLT5's Avatar
Originally Posted by SteveCanyon View Post
I ordered 2 of the pumps from Rock Auto and will order the injectors from Jerry's with the gaskets.
Get the new, not rebuilt injectors
Old 05-04-2015   #24
That's all we carry....New
Old 05-04-2015   #25
Kevin
Kevin's Avatar
hope my thread was able to help you guys.
Old 05-04-2015   #26
SteveCanyon
It did, I actually had to put a thin shim behind the outside connector to get a good solid contact.
Old 05-04-2015   #27
PhillipsLT5
Jerry is always on top of it
Old 05-04-2015   #28
So is the car going to full power with the switch in full power mode even without the full power light coming on?
I think not but will ask the same question here
Thanks Kevin for the thread on repairing the Full Power Switch (now in -Solutions-)
Yes.....Jerry sets the standards in parts quality, packaging, and Delivery Speed (Response)
Old 05-05-2015   #29
Craig,
Although it may well be a funky switch (on the 90 can we assume?), but know too that if there is a fault in progress, the ECM will shut the SPTs off. I'd check out the switch, for sure, but the switch may or may not be the real issue.
Just sayin...
If the bulb in the DTC is burned out, then yes the secondaries will continue to operate: all is well. Otherwise, the secondaries are not opening, and 5500 is about all you can squeeze out of the motor.
Clear as mud?
Old 05-05-2015   #30
Clear as mud?
Paul .....if you have a bad switch I assume the light will still come on with everything else with switch on. How difficult to change bulbs?
What is the bulb size/number?
