10-10-2013 | #41 | |
Re: Where has my DM log data saved to?
Not sure exactly how to do that here Dominic...
Is it taking up too much server space? Or hard to follow? Or both??? Quote:
10-10-2013 | #42 |
I wouldn't worry about the short term mix as it should change rapidly but the Lterm is quite a bit different from my car. My Lterm stays between 128 and 130 both sides. Since this is a snapshot in time it looks to me that the left side was quite a bit lean and the right side was slightly rich on this particular record which looks to be the last record recorded based on the black bar that moves across the screen. So observe the Lterm as the record runs from start to finish. Something else I see different is the voltage. Yours shows 12.7 volts but mine shows consistently at about 13.5 +/- .2 volts. Hmmmm..
10-10-2013 | #43 |
Hover mouse over 12.7, it says, "Ignition Voltage, Volts".
What is that? WHERE is that? Alternator Field Output on the output terminal? Actual voltage @ the battery? It DOES go up to 13.3 during the recording. I enlarged the window, and recorded for YouTube - uploading now... @ about 1/3 of the way through the stream, just as I exceed 1.6% throttle, it goes to Open Loop. Fuel Trim Cell also defaults. TPS % will NOT register between 1.6%, and 2.4%. The TPS sensor and circuit are in perfect order.
10-10-2013 | #44 |
10-10-2013 | #45 |
Wow, never seen that on my car. Voltage is ok then but why the single momentary open loop at initial 1.6-2.4 % tps? It seems as if there is a flat spot on the tps but I think you said you changed it. Correct? Also, have you ever replaced the O2 sensors? One side seems to be lean at idle.
10-11-2013 | #46 |
Fuel filter is replaced. We'll try a few times to double-prime the rails, and see if it will prime above 44 psi.
Then cap off the FPR and re-test, to check spring tension. Obviously no rupture in the FPR bladder, to the FPR vac hose, because there's no leakdown. Ideas here?
10-11-2013 | #47 |
Behind the glove box up in the harness area and there are two of em side by side. Bring a flash light and you best shove your head up the passenger knee bolster attitude. GC
10-11-2013 | #48 |
Re: Throttle hesitation diagnostics?
Did you pull the vacuum hose to the FPR to see if any diff?
10-11-2013 | #49 |
Would you again describe the hesitation? When is it happening, what controls are in play? Are you surging at a steady idle?cruise?
10-11-2013 | #50 |
No - haven't tried with vac source off of FPR...
It holds perfect smooth steady idle at 0% throttle there Dominic. Only on SLOW pedal depression, @ 1.6% throttle, does it start to lope idle. No stumble, missing, anything. And in Cruise, any speed, it has 2mph swing. After 2.4%, it smooths steady RPM increase again. I can replicate it accelerating, but only with LIGHT pedal increase. I can't get a code to light up.
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-11-2013 at 05:07 PM. |
