Old 12-12-2005   #1
black92
Default headlight switch cover
NEED HELP info on removing headlight swith cover on my 92.
black92 is offline   Reply With Quote
Old 12-12-2005   #2
Aurora40
Aurora40's Avatar
Default Re: headlight switch cover
Do you mean the switch on the dash?
Old 12-12-2005   #3
black92
Yes, sorry should have specific.
Old 12-12-2005   #4
Aurora40
Aurora40's Avatar
It looks to be all one unit with the dimmer thing too. From the manual:
Remove:
  • negative battery cable
  • cluster (as described elsewhere)
  • screws on right of trim plate (they go straight into dash)
  • screws on trim switch plate (these go in sideways on the left side of the dash)
  • I/P harnes connector
You should really get the service manual, it's well worth it. Let me know if you need info on removing the cluster.
