Old 12-29-2011   #1
xxxscimitarxxx
Default just replaced all my brake lines .....never again!
last year l was poking around (always a bad thing to do) and saw some corrosion on the brake pipes as they entered the ABS pump box behind the drivers seat....one touch and the fluid started running....then another pipe....then another place...they were rotten through in all the little hard to see places
so first l replaced rotors, pads, flexible rubber with braided....l was basically trying to avoid ripping out the brake plumbing but eventually had to do it
cuts cursing and more cuts and a lot more cursing !, l think l bled more out of my hands spannering at the ABS pump than plunging them into a bucket of broken bottles. eventually got the rusted bolts off the ABS pan and dropped it down. then every unuion on the ABS was frozen on of course....that and every union on the whole brake system of course
eventually l got the main drivers side pipe bunch out after grinding off the plastic clips that hold the 6 pipes in place under the rocker
then there were the brake pipe cross overs....grrrrrrrrr
obviously when the car was made the crossover and corner brake piping was put on the frame with the body off. then the body goes on making a sandwich of the whole affair which is never intended to come out ....how the hell was l going to thread stainless preformed pipes around the tiny chassis spaces and to all the corners
so dumped the stainless idea and went with Cupronickel 'kunifer' brake pipe...thank god for that stuff....if its good enough for aston martin its good enough for me and was a whole lot simpler to bend, flare, and route to all the corners and across the car. Even if it wasnt identically bent to the pieces l took off it was functional and worked
so the end result was a lot easier than lt first looked but still a bitch ...l wouldnt want do it again unless someone paid me for it
however end result was that by poking about and doing the job was that l probably saved my life from some certain disaster when the rotten brake piping would have given out at a life altering moment
A whole brake line job is not for those who want a little weekend project...though lots of beer will help calm frayed hands and nerves
xxxscimitarxxx is offline   Reply With Quote
Old 12-29-2011   #2
Scrrem
Scrrem's Avatar
Default Re: just replaced all my brake lines .....never again!
Yeah, that's the job I think I fear the most...trying to duplicate all those bends is damn near impossible. They without a doubt bent all the lines, installed them, then built the rest of the car around them. Mine are starting to look a little ratty but seem to be sound for the moment.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-29-2011   #3
xxxscimitarxxx
The hardest part is stripping the old stuff out. The fear bit is thinking you have to replicate all the bends exactly. Just the main runs down the rocker from ABS pump to front are doable and then only approximately...at the end of the day it doesnt matter where they go unles you are some kind of concours purist and without doubt dont go stainless. Its a PITA to work with and cupronikel/kunifer works just as well. With cupro you can virtually bend everything with finger and thumb except for some tight radii. Plus the cupronikel flares easy using a cheap flaring kit. At the end of the day if the brake pipes end up running somewhere thats just convenient and clamped down with a cable tie...dont worry about it....l got rid of a few pointless bends that way
Old 12-29-2011   #4
Blue Flame Restorations
Corvette Central offers pre-bent lines for most C4 years. I plan to order the closest year and use what I can and bend up what I'm forced to.
Glad to hear you got it done!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-29-2011   #5
gbrtng
gbrtng's Avatar
Was the corrosion from the outside or inside?
Did this vehicle have regular fluid flushes?
Old 12-29-2011   #6
Oh man what a job! My hat's off to you on that one.
Now I have another thing to check this winter. I rarely even look at the ABS pump. I'm afraid I'll give it some bad ideas if I start looking.
Hey, wait a minute. If our lines are s/s, how the heck did they rust thru in the first place? They have to be some cheap alloy or pure steel? Real s/s doesn't rust if it is at least 18/8 or better.
How did you bleed the ABS pump? Did you have a TECH1 or 1A?
Old 12-30-2011   #7
xxxscimitarxxx
In order of questions....
I think the 5 prebents from ABS to front will be ok to install except as you go up to the front passenger side brake crossover pipe as it crosses the engine bay area, and driver side a bit easier. Two front and rear brake main supply pipes from rez to ABS connect to braided pipe coming from the reservoir (at least on my car) and low down near footwell so not so bad, and one 1/4" has a jubilee connect to rez rubber return (again at least on my car it is) also low down. Then each rear wheel seems to have especially complicated pipe bends which if supplied as bent l cannot see how you can thread it through the frame route without removing a lot of parts. Then theres the rear cross over which goes between batwing support and body, runs along rear chassis frame rail connector (two clips hold pipe) also a PITA to route if prebent....Im sure its possible to gently bend the stainles for a while but it will work harden at some point if manipulated too much
I think if l was in the US l would have ordered the stainless prebents as well and used what l could but as car is in UK the cost of shipping is stupid
As for how corrosion...definately outside .....car came from florida so that could have had something to do with it....that and coming to UK didnt help it with our weather and use of road salts in winter (mine is no trailer queen and gets driven as often as possible) the corrosion l found worst was as all 7 pipes go through an innocent rubber strip as it enters the ABS box. A lot of crap can get kicked up there and it will hold water
As for stainless on our cars.....they didnt come from factory with stainless l dont think, just hardened steel
As for bleeding......no luxury of Tech 1/1A lm afraid....just power bled all four corners and then the ABS bleed. It seems to have done the job and pedal is firm
However, did all this when l was last back in UK and havent hooked up the ABS elec bits and havent driven it yet. Brakes are now firm and seem to work fine with car on four axle stands But lm sure its going to throw up faults and codes....cross that bridge when l come to it
And a question from me
One strange thing l noticed while working on it.....l was able to start the car with all ABS disconnected but it wouldnt rev and would trigger a very low rev limiter if l tried......is this some kind of safety mode that ensure you dont have power if you have no ABS hooked up
Old 01-01-2012   #8
gbrtng
gbrtng's Avatar
I have routinely disconnected the red power feed to the ABS unit and saw no indication other than a check ABS light in the DIC. Not sure what you mean by all ABS disconnected.
Old 01-02-2012   #9
xxxscimitarxxx
ahhh....might have got that a genralized.....to get the ABS free to work on i disconnected all the wiring loom connections in the ABS box.....not sure that l was unplugging but l unplgged everything....and when started in that condition it wouldnt rev
added a pic of my tube plumbing
Old 01-02-2012   #10
TCurtner
How did you (does one) bleed the ABS unit? I see no bleeder valve - is it hidden?
TCurtner is offline   Reply With Quote
