Old 06-22-2012   #1
Don in VT
Default Leaking oil low oil pressure switch
Hi All,
Had a massive oil leak that is now 90% fixed. The pan gasket job went very well and the pan is clean inside and the gasket is tight with no leaks. Now we find that there is still s small leak that turns our to be the low oil pressure switch located under the oil filter housing. FSM says that the coolant must be drained. to pull the filter housing, Is this really true ?. I am sure many of the members have replaced the leaking switch and perhaps I could get some real world tips on this fix.
Best Regards,
Don
Don in VT is offline   Reply With Quote
Old 06-22-2012   #2
Default Re: Leaking oil low oil pressure switch
Don,
I agree with the coolant draining - not much, just enough to remove the cross-over pipe, as the oil filter housing needs to come off to change that low oil pressure SOB. 3-4 bolts and the housing comes right off, no big deal.
The oil cooler lines...may not have to come off, tho I did remove them too - perhaps I could have done it w/o removing the lines? (You'll have to see and get back to us!)
Jerry has a new oil flter housing gasket, if you need one, or if the gasket is intact, a smear of the Permatex (powder blue color) RTV will do the sealing, after getting the housing and the gasket surface clean and dry.
P.
Old 06-22-2012   #3
Don in VT
Hi Paul,
Thanks for the reply. I have to make another plenum dive so I would drain a little coolant anyway. Do I need any special tool to remove the switch ? I have a great specialty tool that is made for O2 sensors that might be handy.
I have already ordered the gasket from Jerry and I am prepared for the new experience.
Your process sure beats the FSM approach so thanks again for the help.
Best Regards,
Don
Old 06-22-2012   #4
Tyler Townsley
Can be done without pulling the filter housing. Use a stubby skt with a socket for a sensor.
Tyler
Old 06-22-2012   #5
Don in VT
Hi Tyler,
Sounds good but how do you actually get the socket in there? I can't even get my small hand in to disconnect the connector.
Cheers
Don
Old 06-22-2012   #6
I ended up just removing the housing, its just a few bolts....
Old 06-22-2012   #7
Tyler Townsley
Originally Posted by Don in VT View Post
Hi Tyler,
Cheers
Don
It was 13 yrs ago and I have a small hand. I never even thought about removing the filter housing. Back then we had no forum and were on our own.
Tyler
Old 06-23-2012   #8
Hi Paul,
Best Regards,
Don
Yes, and as I recall, I bought the special socket for removing it, but as you said, I couldn't access it to use the dang thing. The sensor socket wasn't cheap, and I ended up not using it after all. As Lee said too, once I decided to just pull the housing, that turned out to be a piece of cake way to replace it. Had the dang housing off, the switch replaced, and the new one installed in little over an hour.
And, yeah! Like Tyler said, thank heaven for this forum!
P.
Old 06-23-2012   #9
Don in VT
Hi,
I want to thank everyone for the great responses. As soon as the gasket and the switch arrives I will make "getter done" as the saying goes.
Thanks again
Don
Old 06-23-2012   #10
dan1495
I am still new to these cars, but I just recently changed the oil pressure sensor you are referring to. I didn't remove the coolant pipe but kind of wish I had. I did remove the oil cooler lines from the cooler and would definitely recommend doing that. I also bought a sensor removal socket (1/16" I think) at Northern Tool for about 3 bucks. Not professional grade but it workd fine in this case.
As an aside, my sensor was leaking a little but I think the major source of the leak was that fact that one of the oil filter adapter bolts had worked loose. I have read of others having the same issue.
I admire the person that can do this job in an hour!
dan1495 is offline   Reply With Quote
