Old 09-05-2012   #1
ALZR1
Default 33 Spline
absolutely perfect axles I mean the machine work is bar none.the u-joint caps
were also supplied as well as the socket head bolts and screw on studs for the bearings.
The shoulder just below the splines measures 1.450" and the reluctor ring/ABS ring fits just like the stock one does (press fit).
Here are some pics of the axles,beaerings,screw on studs already screwed on the bearings,u-joint caps,hardware and side by side comparison.
ALZR1 is offline   Reply With Quote
Old 09-05-2012   #2
ALZR1
Default Re: 33 Spline
Attachment 1888
Attachment 1889
Attachment 1890
Attachment 1891
Attachment 1892
more pics
Old 09-05-2012   #3
very nice!!!!
Did you put new hubs on too? If so, what kind?
Old 09-05-2012   #4
Blue Flame Restorations
Sweet machine work, Al!
Let's put it to the test this weekend!!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 09-06-2012   #5
Pete
Pete's Avatar
Pictures don't do them justice,i saw these axles man they are beefy.
They are huge and nicely done.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-06-2012   #6
Awesome, Al!
See you 4 pizza Saturday?
Old 09-06-2012   #7
Me likey !!
Old 09-06-2012   #8
Question Re: 33 Spline
I assume this is a upgrade for racing applications? Is this beefier? I admire the machine work but I dont know why other than to be able to handle the extreme horsepower transfer? GC
Old 09-06-2012   #9
ALZR1
These axles are pure racing products.
This is an upgrade for anybody that breaks axles.They are beefier the stock axles below the splines at the shoulder measures 1.235".The new axles at the shoulder measure 1.450",and Remember these axles are made out of A much better material.
AL.
Old 09-06-2012   #10
Jagdpanzer
Jagdpanzer's Avatar
Al,
Excellent design and supurb machine work.
I'm sure these will be the last set of spindles you will be installing.
Which company supplied these?
They do not look like the larger spindles some have got in the past from Summers Brothers out in California.
Base on this setup what component in the drivetrain do you now consider to be your weakest link?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
