Old 10-14-2012   #1
garyhugo
garyhugo's Avatar
Question Flushing ABS brake system fluid
Is there any special procedure to flushing the fluid because of the ABS ?
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 10-14-2012   #2
garyhugo
garyhugo's Avatar
Default Re: Flushing ABS brake system fluid
Is this to dumb of a question or is the new guy not worthy of a response?
Gary
90-1572
Old 10-14-2012   #3
Jagdpanzer
Jagdpanzer's Avatar
Nothing special, just keep the brake fluid level up while flushing and bleeding all four brake calipers.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-14-2012   #4
scottfab
scottfab's Avatar
Don't flush that which is sitting in the reservoir through
the system. No need for it. Get what you can out of there and
put fresh in. (kinda obvious but thought I'd say it anyway)
Scott
Old 10-14-2012   #5
DaveK
Article on bleeding from the registry website:
http://zr1netregistry.com/ZR1_brakebleeding.htm
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
Author of fast-paced, sci-fi thrillers.
Old 10-14-2012   #6
scottfab
scottfab's Avatar
Thanks
Dave
Sorry, there's just too much wrong with that write-up for me to recommend it.
You don't need a syringe. A turkey baster (new) works fine.
You don't nee a power bleeder.
and MOST importantly do NOT use tissue paper in that master cyl.
The fine paper particulates are very BAD for your system.
Use lintless paper or a clean shop rag and look closely for anything
left behind. Even very small contaminates are additive and will accumulate at the worst places.
Scott
Old 10-14-2012   #7
garyhugo
garyhugo's Avatar
Thank you all for the responses. I feel confident about doing the job right now.
Gary
90-1572
