Old 04-12-2013   #1
AtsZR1
AtsZR1's Avatar
Default Antenna Issues
My radio antenna is stuck in the up position. The motor is running but it will not retract. Any advise?
2021 Stingray Z51 SGM
1991 ZR1 SCG Enhanced
1967 BB Roadster
1963 Split Window Coupe
1954 Roadster
AtsZR1 is offline   Reply With Quote
Old 04-12-2013   #2
Default Re: Antenna Issues
Order a remast kit it appears the mast ribbon is internally broken or stripped
Old 04-12-2013   #3
AtsZR1
AtsZR1's Avatar
Thanks...Dealer or aftermarket part?
1967 BB Roadster
1954 Roadster
Old 04-12-2013   #4
aftermarket is fine madvet.com has them they also have the whole replacement atennas
Old 04-13-2013   #5
AtsZR1
AtsZR1's Avatar
Thanks, it's on order! Installation looks pretty simple. Thanks
1967 BB Roadster
1954 Roadster
Old 04-24-2013   #6
I just replaced the mast in my 91,the odd thing here is that reception isn't as good as it was with the original antenna mast yet the 2 masts look the same.
Old 04-24-2013   #7
If your still using the factory radio it might be the "Bose Tuner Brain" Jeff and have nothing to do with the antenna. Just a thought GC
Old 04-24-2013   #8
scottfab
scottfab's Avatar
How was the replacement mast connected to the coax?
If a socket was used, good.
Then the issue may be impedance mismatch or a tuning issue.
If it's tuning there will be a "tweaking" cap to use that would be
factory set for the antenna they used. It's on the receiver side right
where the coax plugs in.
If it's an impedance mismatch your probably SOL.
The most common one is a 50ohm antenna on a 75ohm system. Car parts houses look at and antenna like a lot of things. It looks like an antenna so it must be one and they're all a like right? Nope.
For more info look at page 2 here:
http://www1.electusdistribution.com....d/impmatch.pdf
Scott
Old 04-24-2013   #9
Scott is this true if he simply remasted his old antenna? He did not replace the old antenna housing and motor etc. The mast does not connect to the coax except via the housing. So if that was not changed I don't see the lol connection. Gc
Old 04-24-2013   #10
scottfab
scottfab's Avatar
Yes, the antenna may not be a matched. If it's a cheap knock off especially. Hey, I had this happen to me on my explorer and should have known better. It was a cheap knock off from Mexico.
All the "housing" does is hold the connector for the antenna. That is the reason I asked how it was connected. Stripping a few wires and using black tape has been known to happen.
Scott
