Old 07-31-2013   #1
oricale
Default Transmission/clutch whine when clutch is NOT pushed in.
Alright all,
I just installed new:
clutch master
clutch slave
clutch line
transmission with 32,000 miles (operated fine when pulled
I start it up and there is a obvious whine.
when i push in the clutch whine goes away.
did not have a whine before.
*possibly a need for more bleeding of the clutch???
oricale is offline   Reply With Quote
Old 07-31-2013   #2
WVZR-1
Default Re: Transmission/clutch whine when clutch is NOT pushed in.
Originally Posted by oricale View Post
Alright all,
clutch master
clutch slave
clutch line
What pilot bushing/bearing is in the crankshaft?
Old 07-31-2013   #3
oricale
What about throwout bearing?, How can I check to see if that is the cause?
Old 07-31-2013   #4
WVZR-1
I've never done it but I don't know why you couldn't use a stethoscope on the fork and just in the general area of the flywheel-housing and the transmission itself. I would think the stethoscope on the fork would be the first place I'd go.
Old 07-31-2013   #5
secondchance
http://www.powertorquesystems.com/Co...rvetteMain.htm
If pilot bushing Jim sells solid and fluted.
If TO bearing you are going to have to hunt for awhile - tough to find.
Old 07-31-2013   #6
We have the fluted AC Delco bronze pilot bearing too.
http://jerrysgaskets.com/store2/root...roducts_id=780
Old 07-31-2013   #7
oricale
Jerry,
Dont know if thats the problem,..but cant hurt to have one,
Get me a price for both pilot and throw out bearings.
Old 07-31-2013   #8
gbrtng
gbrtng's Avatar
The pilot bushing is not in play here - all rotating parts are at the same speed (crankshaft, flywheel, tranny input shaft).
Old 07-31-2013   #9
oricale
Elaborate sir!,..
Old 07-31-2013   #10
WVZR-1
I saw the NOT after I had posted but left the post as a matter of interest into which was used if any at all, maybe it was the original one and NOT serviced but it's pretty common practice to replace on each removal of transmission by some. Was the flywheel inspected, pressure plate and disc removed for inspection and is the fork attached correctly to the pivot stud.
I also didn't see any mention of what had or hadn't been replaced other than hydraulics and was the transmission the one that was in the car or a replacement from another car with the 32K miles. That's a little vague. If the flywheel housing was removed and the transmission is from another car it may not like the orientation to the center-line of the crankshaft. I've never seen it mentioned when doing anything with an LT5 but what about offset flywheel housing dowels**
** is there dowels?
Just askin'
