Old 08-14-2013   #1
KJL
Default Injector Housing to Head Port Match, Steel Gaskets?
While addressing an issue regarding injection housing fuel injector seals, Jerry, from Jerry's LT5 Gaskets and Parts pointed out the housing I was describing was not for my 95 ZR-1 but for an earlier model engine. After pulling the intake plenum i noticed a port miss match between the injector housing and the head. Didn't think much of at at the time but given this new information, I thought I would attach a photo that represents the issue. Some ports are a bit better but this was one of the worse cases. Please note that the housing was ported by the previous owner who decided to use a non-stock housing and intake plenum for porting and powder coating. Unfortunately he no longer has the original parts. I guess my question is, is this common, if not, what can be done to fix it or at least improve it?
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
