![]() Join Date: Mar 2006
$125 shipped to lower 48
I used these with GS offset wheels.
Jon R. Member #490 1992 ZR-1 Arctic White/Red 2008 Z51 Silver 6 spd (Daily driver) ![]() |
![]() Join Date: Sep 2013
No, but the fit is perfect. I used with gs offset wheels for the rear. Drm still sells these and there may be more information on their site. Thanks
Yes, 1/2" longer.
![]() Join Date: Oct 2004
The OP's spacers are nearly 16mm which is what I had done for my car with GS 50mm offsets. These would do anyone that wanted/needed well. Mine weren't sourced from DRM but were done to my specifications and I specified 16mm. If I were doing it again I'd likely do 18mm but these nearly 16mm's will do real well. The rear studs are a very straight forward install with just a minor chamfer done on the stud head so you can avoid removing the hub to do the install. I did GM studs at the time and they were very inexpensive. Today "not so inexpensive"!
#7 | |
I use the same set for my race wheels - they are high quality.
In fact, fwiw after having left them at home once, I just leave them in place when I put the street (OE) wheels back on. Fit is fine, and when I'm on the street wheels I do not have long studs looking a little funny. GLWS, - Jeff |
