Old 10-28-2014   #1
72warbonnet
72warbonnet's Avatar
Unhappy Clicking / Ticking Noise - Diagnostic Help!
Problem: LT5 has just recently developed a pronounced "ticking" or "clicking" sound/noise that seems (via "stethescope") to be coming from under the right-side cam cover.
Facts: '95 stock LT5 (with Haibeck chip) at 13,500 miles. Just changed oil (Mobile-1, 5-w-30) and oil level shows fine at rest. One semi-long (and semi-fast!) trip since oil change. Noticed noise at the end of that trip (may or may not be related to the oil change...) Noise exists at start-up and remains when warm. Increases proportional to RPMs.
Question: From what I've read, it might be a collapsed lifter?? Other likely options and other recommended diagnostic checks??
THANKS!
Bill
Bill
'72 Coupe
'95 ZR-1 (#318)
'03 50th Ann'y Convertible
HISTORICAL FILES:
'86 Coupe (4+3) -- SOLD 2013
72warbonnet is offline   Reply With Quote
Old 10-28-2014   #2
Scrrem
Scrrem's Avatar
Default Re: Clicking / Ticking Noise - Diagnostic Help!
Bill, Are you sure the noise is coming from under the cam cover? Reason I ask is, Jim Voter had an issue with his 90 a while back and it turned out to to be a crack in the air tubes on the stock exhaust manifold. It sounded like a ticking noise too but after Mark H. started feeling around, found the cracked air tube. Something worth checking. I have always used 10W-40 in my Z, 5W-30 seems a bit light for me. JMHO.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Tags
clicking, noise, ticking
