![]() Join Date: Nov 2016
Today I discovered I have a coolant leak on the passenger side.
The leak seems to be coming from the lower radiator hose (the one with the mesh) but I can't tell for sure as it is pretty much spaghetti down there. I'm not getting drips on the concrete but clearly getting splotches, seepage and spray on the passenger side of the engine hoses. The coolant is on the horizontal frame under the lower hose and the oil cooler hoses are wet on the underside. The spray will go as far as the "A" arm bushings but not past the center of the engine. I cleaned it up a few times so I could put an eyeball on it to locate the leak. I can not seem to re create the leak at idle or low rpms. Now, if I take her out and get on it a bit, I pop the hood and I have coolant all over the general area. My question... is there a "typical" place in that lower radiator hose area that leaks that I need to be checking? I had a bit of coolant on the radiator, but I can't tell if that is the cause of the leak or just the over spray. I'm typically not one to throw parts at a situation but I ordered a full set of hoses from Jerry's as PM and hopefully to solve my issue. The hoses are original so they need to be replaced anyway. Anything else that need to check?
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] |
![]() Join Date: Sep 2008
Bill,
Although I would simply replace the lower hose ( because you have them)and go from there, here is the proper way. Mityvac MV4560 Radiator/Cooling System and Pressure Test Kit s/b $50.00 or less ![]() Marty |
Check the Heater Coolant Return fitting at the Thermostat Housing
Heater Return Fitting Rather than just idle and low rpm.......rev it up and check from above as someone revs it up a bit. The Radiator Drain Plug might also be a place but in general it could be any one of the lower radiator hose ends from water pump to thermostat housing or between thermostat housing and radiator. Or as Ted suggests....the Water Pump. Speaking of the Radiator Drain Plug.....my worst leak ever was a coolant leak from a new Ron Davis Radiator I mistakenly installed the provided Aluminum Allen Head Drain Plug (with Permatex). NEVER Install an Aluminum Plug in a Aluminum Radiator......it would not stop leaking and had a time trying to remove it as it galled the threads. After re-threading and installing a Brass Plug....with Permatex....same thing....would NOT stop leaking. So.....I got a nice clean second 1/4 inch Brass Plug and applied Blue Loctite over night before refilling radiator. NO LEAKS.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-29-2017 at 07:14 AM. |
![]() Join Date: Jan 2006
Check the water pump weep hole. The belt can sling the coolant all around.
Ted |
Thanks for the suggestions, I'll check them.
I'm going to dig around tomorrow a bit and see if I can find the problem, before I tackle the whole hose mess. My guess is that the hole is small and just started so it won't leak (lots) until under pressure. The lower hose seems to rest on the frame and may have worn through after time?
![]() Join Date: May 2010
Bill,
Besides all the other recommendations, if I can suggest my best friend the digital inspection camera. http://m.harborfreight.com/digital-i...not%20provided It is amazing where you can get to and see with this. It has a mirror, hook, and magnet too. Handy for leaks and getting dropped bolts and stuff. I know Cliff has one for sure. Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
![]() Join Date: Jan 2015
I bought a Stant coolant system pressure tester decades ago and it has been my best tool investment ever, I can't tell you how many times I've used it and it always helps.
![]() Craig, thanks for this suggestion. Looks like I might have a new favorite tool. :-) Last edited by RussMcB; 01-29-2017 at 09:39 AM. |
Great minds are thinking! Thanks!
#9 | |
Russ, You're welcome and thanks for the reminder about the Stant tester. I had one way, way back and not sure where it went. I will order one of these and add to the tool box. With the camera you will be amazed with what you can find; especially under the motor on the frame and in cavities and leaks in weird places. Sent from my iPhone using ZR-1 Net Registry
#10 |
So, this today, I'll presure test the system---cold. Hopefully it will show me my problem.
Questions... is it better to pressure test from the radiator cap or the coolant reservoir cap? Logic tells me that either side will work, but is there a preferred methods and why? Thanks!
